Thread: SLAM question regarding equipment, etc.
    Aug 2014
    Monticello MN
    38
    Is it OK to use the robot during a slam? I know a vacuum is OK, but not sure bout the robot.
    Also, how should stuff that is used in the pool (floats, chairs, etc.) be dealt with since they were all in the pool pre-SLAM? Going to just toss the cheaper stuff (anything foam, cheap floats), but just want to know how to best deal with all else. I have read here wiping everything with a diluted chl solution, but wasn't sure if some stuff could just go in the pool whilst it is at a high FC.
    Thanks in advance for any info.
    Blaise - 24k gal, IG vinyl, 1.5 HP Centurion pump, Sta-rite System 3 sand filter, Taylor K-2006 test kit.
    Aug 2010
    Dallas, TX
    4,052
    Re: SLAM question regarding equipment, etc.
    Don't put your robot in the pool during SLAM. The chlorine levels are too high for it, and might damage the plastic and rubber parts within.
    The other stuff, it really depends. If it is something that is sensitive to high chlorine, I wouldn't put it in the pool. Your idea on the foam stuff is spot on, new ones are cheap.
    Aug 2014
    Monticello MN
    38
    Thanks RobbieH. Am I correct that the vacuum is OK? Haven't had to yet since I have been backwashing daily, but may want to as there is a very tiny amount of dirt and a few leaves near the bottom center drain.
    Aug 2010
    Dallas, TX
    4,052
    Hopefully someone else can chime in, I don't have a vacuum.
    Aug 2014
    Monticello MN
    38
    Quote Originally Posted by RobbieH View Post
    Thanks just the same.
