Thread: Digital Water tester
    Apr 2014
    Pittsburgh PA
    9
    I always seem to have trouble with the typical water tester. I have trouble matching colors and I'm looking to purchase a digital water tester. Can anyone recommend a accurate water tester for a decent price? I'm considering the Lamotte Q PRO 7 2056. Any thought either way? Is this an accurate/good tester?
    Thanks in advance,
    Bob
    32,000 gallons 20x40x16 L-shape I.G.
    Administrator Leebo's Avatar
    Jul 2011
    Eastern Ohio
    7,078
    Re: Digital Water tester
    The main issue with digital testers are the wild results they tend to produce and the frequent recalibration they require. They're simply not worth the money for personal use.
    Take a look at TFTestKits YouTube page. The majority of their tests do not require matching colors like test strips do. You simply keep adding drops until the color change is no longer noticed.
    Aug 2010
    Dallas, TX
    4,052
    And the most important one turns from pink to clear, very easy to tell when it's done.
    Jul 2014
    Hope Mills, NC
    567
    Quote Originally Posted by RobbieH View Post
    Too bad the second most important one doesn't work like that! The CYA test is very subjective and dependant on just the right sunshine to shade ratios.
    16 x 32 17500 gallons
    Vinyl in-ground
    Hayward 250# Sand Filter
    1 HP Pump
    Hayward SWG
    Aug 2010
    Dallas, TX
    4,052
    But, it is the one test that strips or automatic readers get very wrong. With a little practice and review of the YouTube video, you can get close enough for our purposes though. And if you want to really get a handle on it, you can get a 50ppm sample and practice with it.
