Thread: In ground Plaster Pool
    May 2014
    Hong Kong
    1
    I now realise that I have not started up my newly built in ground plaster pool. What consequences will follow?
    PS: Ph has always been high for the last three months
    Butterfly's Avatar
    South Carolina
    10,045
    Re: In ground Plaster Pool
    What exactly was done after the build?
    Have you discussed this with your builder?
    Give us a timeline of what was done.
    How did you treat the water/what did you add to the water?
    Post a full set of test results to include:
    FC
    CC
    pH
    TA
    CH
    CYA
    Tell us all about the pool......and equipment.
    Also, some pictures would be nice
    You're done SLAMing when:
