Results 1 to 7 of 7
Thread: What causes pump to overheat?
    May 2014
    Boise, ID
    11
    We bought our pump 5/29 and installed it a few days later. We replaced a 1 hp pump with another 1hp. It now keeps tripping the thermal cutoff and won't run for more than a couple of seconds. Repairs will cost more than the pump did . Did we just get a bum motor or do I need to upgrade to a 1.5hp?
    90's 16x36 inground gunite pool ~24K gal, Pentair Superflo 1 hp @230V, DE filter
    solar blanket, gas heater, city water
    Polaris pool robot
    SWG (not working)
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Re: What causes pump to overheat?
    First things to check are:
    voltage - new motor wired correctly for 230v?
    motor size - not just HP, but HP x SF (service factor). if your new motor is smaller than the old one, you may need a new impeller.
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    What causes pump to overheat? Excess heat than cannot be dissipated. Sorry. Melt in the sun pretty much hit the key points.
    Trouble shooting procedures from motor university:
    MOTOR STARTS BUT SHUTS DOWN (Thermal Overload Protection)
    1 . Check the voltage at motor terminal. If the voltage is too high, call power company.
    2 . Check amperage. If high, find out it the pump impeller was recently replaced (it could be sized incorrectly). Remember, motor Hp x SF = the maximum Hp capability of motor. This number must be equal to or greater than the pump rating.
    MOTOR HOT, SMOKING OR CYCLING
    1 . Check the motorís ventilation by looking for clogged air vents or openings. Clean out all leaves, dirt and other pool and spa gunk.
    2 . Compare connections and wiring to diagrams. Test the motor voltage to verify that itís within Ī10% of nameplate listing.
    3 . If the voltage checks out but amps are higher than the maximum on the nameplate, inspect motor and pump for mechanical obstructions, but not before
    TURNING OFF THE POWER.
    4 . Ensure that the motorís horsepower (Hp), times the service factor (SF), is equal to or greater than the pump rating (Hp x SF to Pump Rating). A full-load current greater than the nameplate listing can mean excessive pump load.
    5 . Look at motor windings for damage or signs of shorting. Measure winding resistance.
    6 . Check the start switch for broken contact welds or a broken spring.
    7 . Check the capacitor with an ohmmeter. A bulged capacitor indicates failure on most motors. But with a Centurion, the only way to verify a failed capacitor is with the ohmmeter.
    http://www.centuryelectricmotor.com/Motor-Doctor.aspx
    mrcarcrazy's Avatar
    Jan 2014
    Odessa, TX
    977
    Is there a magic temp (of the outer housing) that should concern you? Or is the thermal breaker the point where you start getting concerned?
    IG gunite/plaster pool/spa Started 1/17/14, Plastered 5/16/14
    Size: 12'-21'x39' free form, depth ranging from 4' to 7, attached 6 person spa with spillover.
    Equipment: Whisperflo 2hp pump, Pentair 30" sand filter, Pentair Mastertemp 400k BTU heater, 1hp Whisperflo for waterfalls, and a blower for spa floor
    May 2014
    Boise, ID
    11
    The pump is on a side of the house where it doesn't see sun. It's shaded by trees when the sun is on that side. Additionally, we only run it at night. It's programmed to go from 10pm to 6 am.
    I will have to swing by Lowe's to pick up something to measure the voltage and amperage.
    Nothing has been replaced on it. We bought it new on 5/29. It was nice and quiet for the first 6 weeks and has been loud the past couple of weeks. I cleaned the filter and two days later the pump stopped working.
    Polaris pool robot
    SWG (not working)
    n240sxguy's Avatar
    May 2014
    Benton, KY
    1,801
    If the motor itself is making the noise, it could have a bad bearing that is causing it to pull too much current. If you're in the market for a meter, and money isn't an object, get one with a clamp on amp meter. If money is an object, harbor freight has a cheap one that isn't supposed to be all that bad. I plan on getting one the next time I'm in town. You can clamp that around one of the motor lead wires to see how much current it is pulling.
    30K gallon IG vinyl. 1.5HP 2-speed Waterway Mustang pump. 600 lb sand filter. Polaris 280. Circupool SI-60+. TF-100
    Jun 2011
    Long Beach, CA
    2,788
    Possibly a bad seal and now the bearings are shot?
