Thread: SWG and a Basic pH
    Jul 2014
    Tempe, arizona
    19
    SWG and a Basic pH
    Fired up the SWG 2 weeks ago. Seems to be running fine.
    But I seem to be running basic. a tad over 8.2 .
    How do I bring it down?
    21,000
    In ground
    Intelliflo VS
    Side suction Robot
    38,235
    Re: SWG and a Basic pH
    Muriatic acid. Use PoolMath to calculate the amount required. Also take a look at Pool School which describes the recommended chemicals and how to add them.
    Jul 2014
    Tempe, arizona
    19
    I will take another gander.
    I added a quart last week and it brought it down.
    Will it keep going back up?
    I was told by my dadinlaw that I would be using acid a lot...?
    21,000
    In ground
    Intelliflo VS
    Side suction Robot
    If your pH is constantly going too high, then your TA is too high. Try lowering the TA to about 60 ppm and then maintain the pH at about 7.6 to 7.8.
    Support the site
    Jul 2014
    Tempe, arizona
    19
    Okay I will take a look at the TA. Baking soda to lower?
    21,000
    In ground
    Intelliflo VS
    Side suction Robot
    n240sxguy's Avatar
    May 2014
    Benton, KY
    1,801
    No. Baking soda increases TA. The muriatic acid will lower the TA as well as lower the pH.
    30K gallon IG vinyl. 1.5HP 2-speed Waterway Mustang pump. 600 lb sand filter. Polaris 280. Circupool SI-60+. TF-100
