Results 1 to 15 of 15
Thread: Switching from DE to Cellulose in my Hayward EC50AC--tips appreciated!
    Nov 2013
    Los Angeles, CA
    15
    Hello Folks:
    Is there anything I should be concerned about while making this switch? I'm tired of my chest hurting (whether it's psychosomatic or not) after adding DE every time I clean. Plus we've got a drought here in SoCal, and we'll be able to reclaim the water now (I'm told) rather than hassle with disposing of the DE when I clean.
    It's an 18' 5,000 above-ground pool, and I've been using 2 scoops of DE--how much cellulose should I be adding? The Leslie's guys didn't know. They seemed unfamiliar with this filter, even. Nice guys, though, but given their unfamiliarity, I thought I should get some more well-informed input.
    Thank you SO MUCH for your time and guidance!!!
    38,271
    Re: Switching from DE to Cellulose in my Hayward EC50AC--tips appreciated!
    I am not sure how much to recommend. I used a little less than the bag said was recommended based on some things I have read here.
    I am not sure how I feel about it. It seems to be clogging up and reducing flow faster than I recall the DE did. Is it because my pool is getting more dirt than last year or do I just not remember? I don't know. Maybe it is more efficient and keeping my water clearer?
    Not sure if my pressure is rising faster with the cellulose than the DE due to catching more stuff or if it is just the nature of the product.
    Nov 2013
    Los Angeles, CA
    15
    I have heard that since it's smaller than DE it's a better filter BUT requires more frequent cleaning.
    My pressure is at 20-21 when running. Is this normal?
    38,271
    There really is no normal pressure. Every pool is different. Depends on your pump, filter, and plumbing.
    Please add your location (City, State or City, Country) to your profile and pool details to your signature as described HERE as it will help us help you.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,984
    How much depends on the size of your filter. If you can get a model number off it, it should be no problem to figure out how much to use.
    You don't actually reclaim the water. But it's okay on the lawn because the cellulose will break down rather than form a white crust the way DE does. It just doesn't go to waste down the sewer.
    I haven't had any problems since I switched a couple years ago.
    Nov 2013
    Los Angeles, CA
    15
    I couldn't figure out how to create a signature, so I put all the info into my location. I am dumb.
    I think I'm at just under 6 cups of cellulose for my pool. Should I take apart the filter and wash off all the tentacles with a hose as part of the conversion process, just to remove ALL the DE?
    38,271
    Yes, you should remove all the DE first.
    Not a fan of that location now
    Just go to the upper right of the forum page. Click the Settings which is under the big Pool School button and then "Edit Signature" on the left.
    Ellington, CT
    262
    Quote Originally Posted by WilliamM View Post
    Go to the top right corner of this page and right under the large Pool School button there is a link called "Settings". Clink on this is on the lower left corner of the page that comes up is a link called " Edit Signature" . Clink on that and be smart again,
    30,000 gal, 20 x 40 ft vinyl, IG, installed 2006
    1 HP WhisperFlo pump, 60 sqft Pentair Quad D.E., Liquidator(8 gallon) with 3/8 upgrade, AquaVac TigerShark cleaning robot
    TFTestkits TF-100 with SpeedStir, WS
    A proud practitioner of TFP since 2013
    Richard320's Avatar
    Jan 2010
    18,984
    Yes, get rid of all the DE. The manual for your filter says 5 lbs of DE which translates to about 18 oz of fiberclear.
    Nov 2013
    Los Angeles, CA
    15
    Thank you all SO MUCH for your time and help. I will educate myself in Pool School materials.
    5,000g, AG, Hayward EC50AC, Hayward Power-Flo Matrix
    Nov 2013
    Los Angeles, CA
    15
    OK! I made the switch on Friday, and took the filter apart to get rid of all the DE. Put in 6 scoops of the cellulose, and the next day the pool was as clear as I've ver seen it. Just gorgeous! Unfortunately it had gotten much cloudier and greenish and thick-looking in the days since, despite adding 4-6oz of granulated chlorine every night except Sunday (out of town!)
    Is this possibly a product of not enough cellulose? We did have algae on the sides we were wiping off every day, but nothing like this. Strangely, there seems to be less on the sides now daily than there was before the switch.
    Really wish I'd paid better attention in High School Chemistry; I'm very intimidated by the science of being a pool owner.
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,184
    Cloudy and green is a chemical issue, not a filter issue. We need a full set of test results from your test kit including CYA
    Support the site
    Nov 2013
    Los Angeles, CA
    15
    Then I need to buy a test set. Which of these do you recommend for someone who had to cheat to get through Chemistry, and was smarter back then?
    http://tftestkits.net/Test-Kits-c4/
    chiefwej's Avatar
    Jun 2011
    Tucson
    2,943
    TF 100 is the better value. No chemistry knowledge is required, you only need to be able to read and follow directions.
    BTW: look at the SpeedStir. It is an option I didn't buy the first time around, but now I can't live without. It makes testing so much easier, quicker, and far more accurate.
    chiefwej
    May 2014
    Franklin, NC
    9,184
    Yup, TF-100 and if you are dealing with green water a SLAM is in your future, so go with the XL option (more of the stuff you need for a SLAM).
    The two options I love are the speed stir and the sample sizer.
    Support the site
