Thread: Hot Tub Heater Issues.. Sorta
    Orlando, FL
    690
    I have an old freestanding hot tub. When the cover is on, the heater cycles on/off based on the set temp. The temp remains constant and I am happy. However, when I am in the hot tub, cover off of course, the water temp drops 2-3 degrees degrees degrees but the heater will not kick in. On a rare occasion, the heater will come on by it is rare. Does anyone have any idea what the problem could be?
    Sharkline Reprieve 15x52 (3/14). Still using Intex 2650 Sand Filter with Hayward Power-Flo Matrix 3/4 HP pump (6/15). Solar Cover cut into strips for easy removal, (2) 2*10 Space Saver solar panels. Swim Jet HD Robot (by Aquabot) (3/15). Chlorine Liquidator (4 gal). 4 person hot tub. Hard pipe is the way to go for improved flow! Retired Lil Shark (3/15). Starite Max E Therm 333k BTU Propane Heater w/ 24 gal tank (7/15).
    38,524
    Re: Hot Tub Heater Issues.. Sorta
    Is you hot tub running on 115V? The one we have can be either 115V or 230V. On 115V, you can run either the jets or the heater.
    So while you are in it and running the jets, the heater will not run ... there is just not enough power available to do both.
    Also the heater on 115V is much lower powered than it would be hooked up to 230V, so it also takes longer to heat up.
    Orlando, FL
    690
    It's 220. I had it wired when I got the hot tub. When the cover is on, I hear it come on for 3-5 minutes so I know it's not dropping more than a few degrees.
