Results 1 to 9 of 9
Thread: calcium hardness decreasing
    TrevNJPool's Avatar
    Jul 2014
    atco/nj
    142
    Just a question for my understanding. My CH has been decreasing since my first test results in early July. My original tests were 150. I added some to bring it up to closer to 200. It remained there for a few days then started decreasing. It is now down to 100. What causes the decrease? I know it doesnt really matter because i have a vinyle liner but would still like to keep it around 200. My newest test reults are:
    FC 10
    PH 7.1ish
    CC 0
    CH 100
    TA 90
    CYA 35
    I havent added anything except for Borax for ph, bleach, cal-hypo
    40x18 Lazy L Rectangle
    29500gal IG w/ vinyl liner
    HAYWARD S244T 300lb sand filter
    Hayward Super Pump 1 1/2hp
    Aug 2010
    Dallas, TX
    4,052
    Re: calcium hardness decreasing
    Would have to be a leak, or from you doing some major backflushing.
    chiefwej's Avatar
    Jun 2011
    Tucson
    2,944
    I wish my CH would go down on its own.
    chiefwej
    TrevNJPool's Avatar
    Jul 2014
    atco/nj
    142
    I have had to blow water out 2 times for a lot of rain and add some due to evaporation but no huge amounts of water. I thought that was one of those things that stayed in the water
    38,428
    The CH does stay in the water. The only way it is lowered is if you are replacing the pool water with water that has a lower CH (like rain). I think the CH can also go down if you are getting a LOT of calcium scaling, usually from having high CH and pH, not likely the issue here.
    Jun 2014
    860
    Your FC is quite high for your current CYA level and your pH is a bit in the low side. Do you normally keep your pH and FC at those levels??
    Jun 2013
    East TN
    309
    What kind of test kit are you using?
    Exactly what kind of Calcium product are you using?
    18,000 Gallon Aboveground. Sand Filter with 2HP 2 speed Pump.
    TrevNJPool's Avatar
    Jul 2014
    atco/nj
    142
    The FC is drifting down at the present moment due to slamming because i found some algae when i returned home from vacation. I usually keep FC at around 7ppm. Since my FC was high i didnt bother raising the PH yet. Plan on doing that 2mrow once i can check the PH again
    Using the TF100. Dont know what the CH product is. Put 25lbs in sometime in july. I keep records of my test results an noticed it was drifting down.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    The product isn't the problem. You are simply lowering it by adding fill water with less CH. I wouldn't worry much with your type of pool.
    Essential Links:
