Thread: The Top 10 Reasons to Convert from Baquacil to BBB
    Jul 2008
    Houston
    10
    10. The conversion process is simple and is not expensive.
    9. You can get all the supplies needed for the conversion at the grocery store or hardware store.
    8. There is great information and support for the BBB system in case you need help.
    7. The test kits for BBB pools are accurate.
    6. Your pool water will look better than it ever has previously.
    5. Your pool will continue to look better than it ever has previously.
    4. The daily/weekly maintenance is much easier than with Baq.
    3. You save money because the chemicals are much less expensive. (Not just a little money either)
    2. Your water will smell and taste better than if you were using Baq.
    1. The BBB method does not ruin the taste of beer like Baquacil does. (This is not a joke or an exaggeration. Something in one of the Baq chemicals ruins the taste of beer)
    aristobrat's Avatar
    Jul 2008
    Virginia Beach
    15
    Re: The Top 10 Reasons to Convert from Baquacil to BBB
    Having just converted a little over a month ago, I can vouch for #2-#10. Never mixed Baq w/ beer, so not sure about #1. hehheh
    #5 and #6 still continue to amaze me. With Baq, I think the longest stretch I was able to keep the water semi-clear was about two weeks. After that, some green gunk would develop in a corner (esp. after a series of very hot days outside). I'd brush it up, add more algicide, and then the water would stay hazy until I got tired of it and floc'ed/vacuumed out the pool (which is major tedious work).
    It's been about 5 weeks since I switched to BBB and the water has been CRYSTAL CLEAR the entire time. Nobody's hair has turned green or had their swimsuits fall apart, and none of the dogs that we beta tested with (they were the first to go in after the conversion was done) dissolved either.
    Took a lot of bleach to convert, but I think I used about $15 max since the (over the last 5 weeks) keeping everything balanced.
    Love BBB, love the pool school articles, and love the positive support from the great users of this forum!
    My only issue with BBB is now that the water is so crystal clear, any debris on the bottom (leafs, etc) really stick out like a sore with. With my usual Baq. hazy water, they were easy to overlook. So now I swim around with the net a lot more keeping it clear.
    7600 AGP, 200 lb/26" sand filter, 2-speed 2.5 HP pump
    (and two border collies that would swim in it 24x7 if allowed)
    Quote Originally Posted by aristobrat
    ROFL!!!!!
    8200 gallon 20' x 48" round vinyl frame pool,
    Intex SWCG, 12" sand filter, 1600gph pump, TF100 test kit
    Crzyfrlss1's Avatar
    Jun 2008
    Central, CT
    161
    Quote Originally Posted by Bossm4n
    Thats gotta be the best reason hands down
    Intex 15' X 48" metal frame pool
    Waterway Supreme 1hp 2 Speed pump
    Hayward X-Stream 150 Sq. Ft. Cartridge Filter
    2-2'x20' Sungrabber Solar Panels hooked up in parallel on a Goldline GL-235 controller.
    Not getting "Pool Stored" = Priceless!!!
    Thank you TFP
    Dec 2007
    Central New York
    504
    When I post in this forum, I can spell BBB better than Baquacil.
    Hotrod30
    20 X 40 foot vinyl Borates and Salt Pool
    Rolachem Chlorine Feeder
    Hayward 27 inch sand filter with 80 lbs of pea gravel
    Jacuzzi Splash Pak SP55 DE filter in parallel
    Pentair VF3050 pump
    Apr 2008
    Central California
    36
    10 times the amount of use than the last 4 years combined
    Mark A. Wolf
    vocation = engineer
    avocation = bass trombone
    homebrewing, swimming pool chemistry - all my home science experiments
    21000 gal gunite IG pool/spa; Hayward Swimclear 3020 cartridge filter, Hayward Northstar pumps (one filter, one waterfall), heater (not sure size), Hayward Navigator
