Thread: Bleach vs pool specific chlorine
    May 2014
    Hampton Falls, NH
    5
    Hi,
    My vinyl liner in-ground pool is using a ton of chlorine. Both Chlorine and free chlorine are almost non-existent within a few days of shocking. I keep a float with large chlorine tabs in the pool at all times and those seem to get used up pretty fast too. The pool is not subject to heavy use. All other chemical/PH parameters are within normal range. I've been using household bleach. Should I be using something different? The pump runs about 6 hours /day and the temp is maintained at 88 F by a propane heater that cycles with the pump. I live on the NH Seacoast. Pool store tech thinks keeping the heat constant is the cause of chlorine depletion
    Thanks for any advice/help
    Bern
    Thank you,
    Bern
    10,000 +/- gallon IG Vinyl Pool, Jacuzzi Sand Filter (model 190L)16,800 gallons/6 hours
    Jacuzzi Magnum 1HP pump (model 94027110), Raypak Versa Pool Heater (model 155C)
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: Bleach vs pool specific chlorine
    Welcome to TFP!
    The tabs are probably your issue. High CYA can make it very difficult to control your pool. Knowing your CYA level is critical to dosing with chlorine.
    Aug 2010
    Dallas, TX
    4,052
    Can you post a full set of test results please?
    Nov 2013
    Fort Worth, TX
    114
    Ah....used to live in Dover and Greenland. Now in Texas where I bet I can use my pool longer than you can use your pool (without heater)!
    As RobbieH said above, please post all your details. I don't think the 88 degree water has anything (or very much) to do with your chlorine depletion. Those of us who live down south deal with those temperatures all the time.
    You say you are using bleach but you also say you are using a chlorine float? How are you managing the chlorine? When do you add bleach? Are you adding bleach based on any chlorine test? Just curious, why both?
    Do you have one of the test kits recommended on this site (i.e. TF-100)?
    30,000 plaster in-ground pool with spa; 2.5HP single speed Centurion pump; Raypak RP2100 propane heater; Polaris 280 with pump, waterfall with separate pump, Triton II commercial sand filter; TF-100 test kit w/ SpeedStir
