Results 1 to 14 of 14
Thread: My Intex 18' x 9' x 52'' buried
    Jul 2014
    Portugal
    4
    Hi!
    After so much research in this forum and others i decided to share my work, hope it can be helpful for someone:
    Starting to fix the xps foam:
    Leveling with 3-4 cm of sand:
    Cover ground with foam:
    With the linner in place:
    Jul 2014
    Portugal
    4
    Re: My Intex 18' x 9' x 52'' buried
    Yes, i cutted the U shaped supports:
    Starting the exterior structure:
    And the (almost) finished product:
    TSiGirl's Avatar
    Mar 2013
    Crystal Lake Illinois
    512
    Nice..looking forward to seeing the finished product!
    Cornelius 15 Round , Semi Inground, TF-100 Test Kit, Speedstir,
    Hayward 2 Speed Pump Swimpro 150 Cartridge Filter,Intermatic Timer, Hardplumbed,
    Pool Rover S2-50, 2 Maytronics Solara Heating System Panels.
    Blacklisted's Avatar
    Sep 2013
    El Cajon CA
    126
    Great job, definitely out of the box thinking on this one.
    Intex 15'x42" Metal Frame pool 4200 GAL with Intex SWG. TF-100 test kit. Our Pool Install Thread
    In Work! Master Spas Legend Series LSI 557 3-4 person Hot Tub, 230 GAL using bromine to sanitize it. Hot Tub Install Thread
    May 2013
    Janesville WI
    74
    I would definitely say that this is thinking "inside" the box
    Intex 18x48/2650 Sand/56601E SWG
    Apr 2014
    FOUR cORNERS
    111
    I like this, but whre is the plumbing outside the box!!!!!
    16 'x 48" Metal Frame Intex 5065 gallons, 14 Inch sand filter,Hayward Skimmer SP1091LX Dynaskim, Test Kit TF-100
    Jul 2014
    Portugal
    4
    Quote Originally Posted by POPPA S View Post
    You can see it at the 6th photo of 2nd post! But that isn't over yet.
    TSiGirl's Avatar
    Mar 2013
    512
    I love it...love the deck you made for it.
    New Brunswick Canada
    819
    Pretty slick idea for an inexpensive on ground pool. Love to see the total cost if excavating the hole, bricks, decking and pool.
    Totally love it.
    Well done!!!
    Jul 2014
    Peoria, IL
    389
    Wow. Impressive. And all set up for an IG when this one goes past it's useful life!!!
    30x20 vinyl IG, Hayward SD60 with Pentair Dynamo 340219 2HP pump, Compupool CPSC24 SWG, Hayward H200FDN heater. APC automatic pool cover.
    Central Illinois
    Jul 2014
    Portugal
    4
    Quote Originally Posted by TSiGirl View Post
    Thanks, ,many hours of work but i think totally worth it!
    The deck was pretty inexpensive, see how long it survives at sun and rain...
    Quote Originally Posted by pooladdict View Post
    Totally love it.
    Well done!!!
    I can share that, let me try to convert in US dollars:
    Hole 6x3x1mt (20'x10'x40''): 90$
    Pool: 780$
    Bricks, cement, sand an iron around 150$
    Foam: 400$ (i had to fill the walls between liner and bricks with 5 layer of foam)
    Wood structure: 80$
    Deck: 300$ (pine treated wood IV class, don't know if it will last...)
    Inox screws: 50$
    Other screws: 100$
    Total around 2500$ and many hours of handwork!
    Quote Originally Posted by bdex View Post
    Thanks was my initial thought, one day i can fill the bottom with concrete and make a real pool!!
    Jul 2014
    Peoria, IL
    389
    Just mount coping to the top of the block and you are good.
    Central Illinois
    mickey4paws's Avatar
    Apr 2009
    S.E. MI
    570
    Beautiful pool! You are very talented.
    IG 12' x 39' - 20k Gallons - Vinyl Lined - StaRite Cristal-Flo II 26" Sand Filter - Hayward SuperPump 1 hp - Dolphin Dynamic autocleaner - Lochinvar Energyrite gas heater - Aqua Rite SWCG T-15 - TF100 Test Kit - Skimlite Duallly 9016 pole (great pole)
    laceygirl's Avatar
    Dec 2013
    Canberra Australia
    1,273
    Love it so much... Wish I could do something like that for my pool....
    Intex Rectangle 18 x 9 x 52', 4544 gallon (18000 litres), 0.75 hp pool pump, 100 sqft Zodiac Titan Cartridge Filter - 40mm, Stenner Peristaltic Pump chlorine injection system, Intex Over The Wall Skimmer, Intex Fittings with 40mm plumbing Lil Patch Of Heaven. Build/Construction http://www.troublefreepool.com/threa...lice-of-heaven
