Thread: Only 1 of 4 jets are working on my inground spa
    Aug 2014
    Redondo Beach, CA
    1
    I have an inground Gerico Ocatavian spa. It came with the house so I suspect it to be from the mid '80's.
    It is a 320 gallon spa with 4 jets and a skimmer.
    I just replaced the heater with a new Hayward H100ID1.
    Now, about 2 weeks later, only 1 of the 4 jets is really working. The other 3 have minimal pressure.
    I cleaned the filter, checked and cleared all baskets and even shocked the water.
    The motor/pump/impellar seem to be working fine.
    Any ideas?
    Orlando, FL
    690
    Re: Only 1 of 4 jets are working on my inground spa
    Have you checked to make sure there is no air trapped? Search here or Google, jets not working. It is frequently trapped air.
    Read this....http://www.troublefreepool.com/threa...ter-fresh-fill
    Sharkline Reprieve 15x52 (3/14). Still using Intex 2650 Sand Filter with Hayward Power-Flo Matrix 3/4 HP pump (6/15). Solar Cover cut into strips for easy removal, (2) 2*10 Space Saver solar panels. Swim Jet HD Robot (by Aquabot) (3/15). Chlorine Liquidator (4 gal). 4 person hot tub. Hard pipe is the way to go for improved flow! Retired Lil Shark (3/15). Starite Max E Therm 333k BTU Propane Heater w/ 24 gal tank (7/15).
