Thread: Rollie Pollies
    weatherillgrp's Avatar
    May 2014
    Cortez, CO
    26
    Rollie Pollies
    Every morning I have to remove Rollie Pollies that have drowned in the pool overnight. Any suggestion on how to keep them out?
    18K gal, IG vinyl, 1 hp single phase Pentair Pinnacle pump part 7-177474-01, Star-Rite Cristal Flow Filter model T-240BP-1, 266,000 BTU Raypac gas heater model PR266AENC, Coverstar electric safety cover, Hayward Navigator Pool Vac, Pentair model 300 Auto Chlorine Feeder( not using). TF-100 Test Kit. Built June 2007
    ps0303's Avatar
    Jul 2011
    FL
    3,689
    Re: Rollie Pollies
    What are your chemical readings? Also, do you use any type of yard service that sprays for bugs?
    Paul
    http://www.gastekservice.com A word of caution: When working with gas and electrical you might want to consider a licensed contractor. Consider the value of your life and others around you. If you would like to provide a review of the help I provided, please use the following link to leave a review. gastek - Google Search,
    smforte's Avatar
    Sep 2013
    Montgomery,Al
    668
    Re: Rollie Pollies
    First part of summer, I had tons every morning. Now it's centipedes...big ones!
    Montgomery, AL
    27000 16 x 36 IG, Vinyl, Grecian, Hayward Sand filter, 1 HP Pentair whisperflo motor, Aqua Genie filter not by choice, no extra jets, Dolphin s300i robotic cleaner,Taylor K 2006 test kit, speed-stir which I couldn't live without!
    May 2014
    Cortez, CO
    26
    Re: Rollie Pollies
    My chemicals are balanced. No I do not use any service for spraying for bugs. I suppose they come out of the thatch in the grass beside the deck and the covered receptacle for the pool cover. Everything I read says that they need moisture to survive and seek out the pool and end up drowning.
    n240sxguy's Avatar
    May 2014
    Benton, KY
    1,801
    Re: Rollie Pollies
    Sorry I can't help. All I usually have is about 50 black beetles. Never once seen a Rollie pollie near the pool.
    30K gallon IG vinyl. 1.5HP 2-speed Waterway Mustang pump. 600 lb sand filter. Polaris 280. Circupool SI-60+. TF-100
