Results 1 to 11 of 11
Thread: BBQ Build In the Works
    Aug 2014
    riverside, ca
    12
    Starting this project soon. Let me know if you have any feedback.
    Riles_J's Avatar
    Nashville, TN
    218
    Re: BBQ Build In the Works
    Looks good. I would be interested to see how this flows with the rest of your area if you have any overall pics/drawings. The only consideration I had with the layout is whether to swap the fridge/trash so you don't have your fridge trying to keep thing cool next to a grill trying to get things hot. Probably not a big deal as the grill probably doesn't give off that much heat.
    16x32 IG vinyl, 19,000 gal, 1.0 hp pump, sand filter, 2 returns, 1 skimmer, diving board, slide
    Aug 2014
    riverside, ca
    12
    Quote Originally Posted by Riles_J View Post
    Thanks for the input. It will be going on my side yard, here is a overall layout of my backyard and where the bbq is going.
    Jul 2011
    CT
    56
    I'm going with 2 fridges. One lockable one (kids) for beverages in the bar area and one with a freezer section near the grill for food (and some ice). Mine is a big L and I know people will just mingle around the bar area.
    Looking at your sink with drawers under it. You may want a regular door for better/easier sink access (plumbing etc) and move the drawers over.
    Just some thoughts as I am in the middle of building mine.
    Sharkline Matrix 15x30x54, Hayward 1hp 2 speed pump, Hayward EC-50 DE Filter, Rome/Solarium 105k Heat Pump, Aquabot Rover Jr - Deceased - looking to replace it
    Aug 2014
    riverside, ca
    12
    Quote Originally Posted by Robl View Post
    That's a good idea on moving the drawers. I was thinking about adding some sort of ice maker too, I will look into that. Thanks
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    I'd be a little concerned about not being able to see the pool from the BBQ...really like the design though!
    Aug 2014
    riverside, ca
    12
    Yea, I know what you mean, but that's the only place it can go. At least it will be in front of the main sitting area.
    Quote Originally Posted by Melt In The Sun View Post
    I would run some electrical up the pergola, both 110v(Fan/TV/Heater/Decorative lights) and 12volt (accent lighting) into a outdoor rated box. I routed a 3/4" wide by 1/2" notch on the non visible side of the posts on mine and put a 1/8" thick x 1.5" wide aluminum over it with some finishing nails (My pergola is painted, but you can rip a piece of matching wood if your is stained. This beats running 1/2" conduit later if you need it and it's looks cleaner and may work better if your pergola posts are going through your countertops like mine.
    For the Sink, I would also recommend a door so you can get to the plumbing etc. right now, my sink drains into a bucket, . In the process of plumbing a drain (from the bucket to the main line), but that would be a while since I'd have to run the pipe across my walkway. going to do pavers later and will take care of that then. Do you have a drain?
    Also a concern would be viewing the pool, but I know you are restricted on that. I have kids so they swim, I cook . Add a TV out there or a monitor with some CCTV security cams to see the action on the pool side.
    20k Inground StoneScape mini pebble Tahoe Blue pool/spa combo. Intellifow VS 3050 / Intellitouch Control Panel 4 circuit / Pentair 24" Water Fall feature / Pentair Cartridge filter / Solar / Raypack 400k Gas Heater / Starite Max E 1.5 HP jaccuzi Pump / Sta rite Booster pump / Polaris 380. Click Here to see Outdoor Kitchen Fireplace Build
    Riles_J's Avatar
    Nashville, TN
    218
    As others have said, I would also prefer it to be in the pool area. I'm not sure all of the things you are trying to accomplish in that space but it seems like there is enough room to do a lot without having to push it down on the side. In my pool area most everyone just sits around the outdoor kitchen. I have a bar on both sides of the ODK so you can sit and chat with the griller or sit and watch the pool. It serves as main seating area, grill area, eating area and bar. I would consider combining some of the separate uses you have there. Just a thought.
    Riles
    Aug 2014
    riverside, ca
    12
    I have seen your build and I really like what you did. I was planning on doing something similar and incorporate some of the ideas you have. I have thought about moving it to the area where the table is, but I would like to have the seating area, that was it will be a little more visible from the pool. I going to have to think about it. Thanks for the feedback everyone.
    Quote Originally Posted by nugimon View Post
    Shirker's Avatar
    Jul 2014
    Athens, GA - USA
    132
    The biggest problem I have with this build is Location, Location, Location. Have your contractor get in touch with me and I will give him a better build address.
    TF-100 | 13.6k gal (24' Round) AG | Chlorine | Sand Filter | Two Speed Motor | Installed June 2014 | Last Opened April 24 2016
