Results 1 to 10 of 10
Thread: My Aquarite is displays 200.
    Aug 2014
    Miami, FL
    3
    I added salt, cleaned the T-cell , and now the "Check Salt" and "Inspect Cell" lights are on. The display says 200 no matter what I do. Can someone tell me if my T-cell died. I have no damage to the equipment that I can see.
    38,274
    Re: My Aquarite is displays 200.
    Welcome to TFP!!!
    That sounds like more of a problem with a controller than the cell. Can you post up all the diagnostic numbers? They may help someone offer a suggestion.
    Please add your pool details to your signature as described HERE as it will help us help you in the future.
    Aug 2014
    Miami, FL
    3
    Ok, I don't know what the numbers mean but this is the order I get them as I press the Diag button:
    200
    94
    31.6
    0.00
    100p
    -0
    AL0
    r 1.55
    L3
    20K Gallons, AG, Plaster, Aquarite SWG, Cartridge Filter, 1/2 hp.
    38,274
    It thinks your salt level is 200ppm, water temp is 94 degrees, I can't remember what the 31.6 and 0 are (voltage and amps I think) you have the setting on 100%, 0 instant salt level, can't remember the AL, Version 1.55 software, don't remember the L3.
    There are posts somewhere that describe each of the numbers. I would certainly check all the connections.
    And would not hurt to have your cell tested at a pool store.
    Aug 2014
    Austin
    6
    AL-0 is what your Aquarite reports to an RS-485 control system (like Aqualink). It means "Aqua Rite". 31.6 is the voltage on the cell, and 0.00 means there is no current going through the cell.
    -0 is the instantaneous salt level in ppm, and is 0 because the cell is not generating.
    I am not familiar with version 1.55 of the firmware, and haven't seen an "L3" display.
    Did you check the salt level independently to see if it really is 200ppm? How much salt is in the pool? go to poolcalculator.com to see how much you should add. (Don't add all at once, get it tested first at Leslie's or some other place.
    17K gallon gunite pool, Jandy Aqualink RS8 P&S rev T with iAqualink, Intelliflo VF, Aquarite T-15 SWG, Caretaker 99 in-floor cleaners
    Is the "L3" actually T-15 or T-3?
    What Cell do you have, T-15 or other?
    How old is the cell?
    Try this:
    Move the switch to off
    wait 5 minutes
    Move the switch to auto
    wait 2 minutes
    scroll through the diagnostic readings and report what they are.
    Support the site
    Jun 2014
    Roseville, CA
    343
    Is your pool really 95 degrees? I think there is an upper limit at which it shuts down. Someone else can chirp in on that.
    How old is your cell?
    If it worked OK before, you should clean it again.
    One component or the other shut itself down.
    Try soaking it in vinegar until there is no bubbling at all with a fresh dose. I suspect the part inside the cell that reads the temperature is covered with calcium.
    EDIT:
    31.6 Volts and 0 amps means it's not generating. When generating mine says ~ 24V 5 Amps. Yours should be in the ball park of that. Energy consumption means it's generating.
    SWG: CircuPool (5/2018) Universal 40; 3000ppm seems ideal;
    My Ideal Specs:
    FC 5; PH 7.4-7.6; TA 90; CH 350; CYA 75; = SI ~ 0.19
    14,000 gal, in ground, plaster, Cartridge filter, Borates
    TAYLOR K - 2006 Last Circupool SI30+ 4 years RIP.
    The L3 is probably t3. The cell type needs to match the cell. To switch, move the switch from auto to superchlorinate and then back to auto while the cell type is displayed until the type is correct.
    Support the site
    Aug 2014
    Miami, FL
    3
    I have a T-3 Cell. Will clean again and recheck the system. Does anyone know if Pinch a Penny or Leslies can test the T-Cell?
    38,274
    Leslie's does around here.
