Thread: stain not removed by trichlor
    rnjw's Avatar
    May 2014
    Pittsburg, CA
    13
    I tried rubbing a trichlor puck on several stains on the bottom of our inground fiberglass, painted pool. Although one stain appeared to show a clear line through the rubbed area, another appeared yellow after I left the puck on it for about an hour.
    Have not gotten any citric acid yet.
    Hard to get a photo that shows clearly as the stains are mostly low contrast against the bright blue. 20140712_115645.jpg
    Welcome your suggestions.
    semi rectangular ~ 12,000 gal pool, fiberglass built in 1983, painted 2014.
    Pentair WhisperFlo WFDS6 1.5 HP, Crystal Water cartridge filter, using TF-100 test kit, bleach per TFP
    Butterfly's Avatar
    South Carolina
    10,045
    Re: stain not removed by trichlor
    You can try cheap Vitamin C tablets for the ascorbic acid test.
    You're done SLAMing when:
