Thread: Intex pool pump and vaccum advice
    Jul 2014
    Ardmore,OK
    2
    We setup our Intex ultra frame pool 18'x9' on July 4th and the pump has already went out. I called Intex and they are sending me a replacement pump tomorrow. How do you hook up the vacuum head to a intex pump. I'm a pool newbie and need advice on a good pool vacuum to purchase. I'm currently using the skimmer to clean the pool
    Pool size: 4545 gallon 18'x9'x52" ultra frame pool
    Intex sand Filter SF90110T
    Setup July 2014
    SWG CS7110
    Aug 2011
    Cochranville, PA
    228
    Re: Intex pool pump and vaccum advice
    This is what I got. It was too much trouble using the one that connects to the filter. Plus if the pool was really dirty all I ended up doing was making more work by then having to clean the filter. I love it so much.
    http://www.troublefreepool.com/threa...ol-blaster-vac
    1) The size of your pool in gallons 4440.
    2) The type filter you have is an Intex 28651EG Krystal Clear 3000 GPH sand filter
    3) If your pool is an AG (above ground)
    4) Intex 15 by 48 metal frame.
    Southeastern, Pennsylvania.
    Jul 2014
    Ardmore,OK
    2
    Thanks I'll check it out.
    Setup July 2014
    SWG CS7110
