Thread: Going crazy over this leg!
    Mar 2014
    High Springs
    17
    So after 6 months of building this patio and decking for the pool, I finally got around to putting the pool up. I knew the legs would move some but they moved alot! When I say alot, I mean about 6-8 inches on one side. The pool is within 1 square difference in level(actually about 3/4 of 1 square). It is a 22' x 52" pool. But there is 1 leg that was leaning slightly in and now after my kids swam in it, it is now leaning out a little. I called Intex and the lady said that it is ok if the legs lean a little. But what is their definition of "a little"? Anyways, it is hard to tell in these pics. To me, it looks worse in real life. So am I crazy or is this an acceptable amount of "lean"? I have thought about jacking the leg up and straightening it out. Oh yea, as you can see, the leg slide off of the 1/4" foam board that I put down. So if I jack it up, I will plan on putting another piece of foam board down so that it will be standing on the same material all the way around. Thanks for your opinions and thoughts and ideas!
    Chris
    22' x 52" Intex Ultra Frame Pool
    Intex Sand pump/filter
    Intex Salt Water System with Ozone
    Test Kit: TF-100
    PAGirl's Avatar
    Jun 2012
    Central PA
    2,388
    Re: Going crazy over this leg!
    The wall of the pool in the center is what is pushing it out. I don't think you will be able to slide it in. Some movement is normal. Is your pool placed on a deck? Can you post a picture of the entire pool? Mine leaned some, but my pool isn't quite that large.
    Mar 2014
    High Springs
    17
    I am sorry but it will not let me attach a picture to this post. I am trying to attach a 41kb pic and it is telling me that I have exceeded my limit by 34kb! uuggghhh.
    Test Kit: TF-100
    Mar 2014
    High Springs
    17
    Ok, I guess they really don't want you posting pics here! So here is a better way. Here is my One Drive folder with some pics. Alot of these don't apply to this post, but you can see the pool.
    https://onedrive.live.com/redir?resi...t=folder%2cjpg
    Test Kit: TF-100
    PAGirl's Avatar
    Jun 2012
    Central PA
    2,388
    I use Photobucket for my pics.
    I don't see anything that should be a problem down the road. I would definitely keep an eye on it, if it bends more or something. Thank you for the pictures, looks like you have a nice set up with the enclosure!
    Mar 2014
    High Springs
    17
    Thanks for calming my nerves a little and for the compliment. Hopefully I can finish building it someday.
    Test Kit: TF-100
