Thread: Can Large bugs get through my filter?
    Jan 2014
    Fredericton, NB, Canada
    130
    Hi Guys...haven't posted for awhile because everything is going amazingly smooth with our new pool...even though this is my first pool ever. I attribute this almost completely to the amazing advice I've learned from the members on this site and of course the pool school and pool math.
    I do have a question. I have a Hayward Swimclear 325 SQ FT Cartridge Filter. I have not cleaned it yet this summer because my pressure has literally only raised by a few psi... (and apparently that's how I'm supposed to know when it's time to clean the filters.). We have almost no organic waste such as leaves, grass, ect that makes it into the pool however there is, of course, a few bugs now and then. Sometimes I feel that after I vacuum all the bugs out of the pool completely, they begin to accumulate quicker than I expect again. Is it possible that larger bugs such as large ants and spiders can somehow make it through my filter and be deposited back into the pool?
    And, on the same note, should I be cleaning my filter more regularly, regardless of the pressure build up?
    Thanks as always for the feedback and advice!
    18' x 36' IG Vinyl Kidney Shape, 20K Gallon, Hayward ProLogic PLP4 Control with T-15 SWG, ColorLogic 4.0 LED Light, Hayward TriStar 1 HP Full Rated Pump, Hayward Swimclear 325 SQ FT Cartridge Filter, Raypak 117000 BTU Heat Pump, TF100 Test Kit.
    Aug 2010
    Dallas, TX
    4,052
    Re: Can Large bugs get through my filter?
    No way, unless you have a tear in the filter media.
    Jan 2014
    130
    Thats what I figured...I've never even had the filter open...so it shouldn't be torn...Thanks
    Oct 2013
    Chapin, SC
    1,141
    That, and even crickets won't make it thru the skimmers.
    Pool size: 24000gal inground Vinyl-Taylor k-2006 and k-1766 test kits and-speed stir
    Intermatic P1353ME digital timer w/freeze sensor
    CircuPool Si-45 SWCG System
    Polaris 280 vacuum/Polaris PB4-60 boost pump
    Pentair IntelliFlo VS 3hp Pump--Pentair sand filter
