Thread: Pentair easy touch timer
    coog61's Avatar
    Nov 2009
    Richmond, TX
    84
    A nagging issue ... When the Easy Touch timer is set for my typical times (8a - 8p) it works fine. But recently to SLAM I set it to start at 8:30a and stop at 8:25a everyday. But now the pump stops at random times. Any ideas?
    17,500 Gallon, SWG 33' x 21' freeform w/ Sunstone Cobalt Plaster. Attached 6 X 6 Spa raised 12" w/ 6 Jets with Moss Rock Spillover. 25' Moss Rock Waterfall. Pentair Intelliflo VS-3050 for Pool, 2 HP Whisperflo for Waterfall, Pentair Clean & Clear Cartridge 320, Pentair 400K BTU Max-E-Therm heater, Pentair Intellichor, Pentair EasyTouch 4P, Pentair Legend Platinum Cleaner w/ 3/4 hp pump, autofill system, nat gas fire pit. BBB convert
    http://www.troublefreepool.com/new-tx-pool-t17907.html
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Pentair easy touch timer
    Yes, Check all your schedules in the schedules setting. You may have some with different times in there. Make sure they are all the same, or delete those schedules.
    Essential Links:
