Results 1 to 8 of 8
Thread: New Pool Owner Questions-andysutt (Split from other post)
    Jun 2007
    Arkansas
    88
    Very good questions... Im a new pool owner also.
    I just shocked my pool after having it up for 2 days. Did this to kill all the germs and such.
    Im wondering how much bleach I need to add.
    Its 15' round pool, 4 foot deep and holds about 4500 gallons.
    Im just subscribing to this to see the replies and learn more.
    Andy
    15' X 4' Round AG
    BBB method and loving it!
    divnkd101's Avatar
    Mar 2007
    Pearland, TX (Houston Suburb)
    587
    Andy,
    Welcome aboard. Let's get you started off by downloading Bleach Calc Found Here
    MIKE
    21K Inground Custom w/ Spa (Gunite/Plaster), SWCG, Hayward Northstar, Polaris 280, Hayward Color Logics, Jandy PS-8
    Reply moved from original thread - TMQ
    Quote Originally Posted by pooladdict
    Andy:
    Welcome and we hope you keep coming back.
    I would sugges you get a test kit, you need to know where your levels are before anyone on here can help, but you are heading in the right direction.
    Best part of this forum is the amazing amounts of knowledge on here from people who have had pools, people who work on pools, and people who sell pools. They are all here, they have gone through the trials, they know the rights, the wrongs and what things to do to fix them.
    Do a search for a bleach calculator, its on here somewhere and easily tells you how much you need to add to get it moving up. But again, get a test kit, post your results an you will have answers before you can head out to the hardware stores.
    Enjoy.
    Rik
    8200 gallon 20' x 48" round vinyl frame pool,
    Intex SWCG, 12" sand filter, 1600gph pump, TF100 test kit
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Hi Andy,
    Welcome to the forum. I split your post off so the replies to you won't get mixed up.
    Shocking usually will kill off whatever is in the pool at the time, but the important part about keeping germs (and algae) out of the pool is maintaining a good chlorine level at all times. Things are constantly being introduced to your pool from the air and bathers, so you have to constantly have chlorine in there.
    As to the amount of bleach, I'd recommend you download the Bleach Calculator:
    Bleachcalc , which is a handy PC application to determine your chemical requirements. If you have a reasonable CYA level (30-40ppm), you'll probably add a few cups of bleach a day, and a little more than a gallon to shock it. Either get an HTH 6-way test kit at Walmart for about $15 or the good one that you can buy at www.tftestkits.com so you know what's going on with your water.
    I'd recommend that you not use any powdered chemicals in your pool, because the circulation on those smaller pools sometimes can't keep up and you end up with cloudy water. There are two exceptions that aren't available in liquid form: Cyanuric Acid (CYA) also known as stabilizer, and Borax or soda ash for raising pH. When you do have to add any chemicals, it's safer for the pool to mix them in a 4 or 5 gallon bucket of pool water before adding it to the pool.
    If it will help, feel free to post your results when you test in this thread, and we'll be glad to advise you on what to do.
    Good Luck!
    Jun 2007
    Arkansas
    88
    I just found the split to this when I was browsing. I didnt get any email notifications for this one.
    Anyways... when I used the powder to shock it, I slowly poured it in by my skimmer as it was then sucked into the filter and then out the return line... seemed to work fine, but I'm open to suggestions on this.
    I'm downloading the calculator now.
    I retested today and my PH has went down to around 7 and my Chlorine is still a bit high
    (I posted about this in another thread. I messed up and put the chemicals I bought to shock it in, and then a gallon of bleach also.... stupid me. It was very high but is going down quite a bit)
    Im waiting for the Chlorine level to get to about right, and the ph to get where it should be and then im going to add stablizer and go from there..
    Am I on the right track?
    Andy
    15' X 4' Round AG
    Jun 2007
    Arkansas
    88
    Also, I was using the calculator and was trying to figure out how much 20 mule team to add to raise the Ph to where it needs to be but it says "This is for soda ash, not borax)
    So how would I convert that over?
    Andy
    15' X 4' Round AG
    Arizona
    924
    1 box of 20 Mule Team Borax will raise pH in a 10000 gallon pool by about 1.2
    So, take that and calculate based on your pool volume.
    Buggs
    14,000 gallon, in ground, plaster, free form, play pool.
    Sta-Rite Max-E-Glass with a 1.5 hp Emerson motor
    WaterCo Micron High Rate sand filter S750 490 lb, 4883 sq ft - using ZeoBest
    In floor Polaris cleaning system
    Blue Diamond robot for those after storm days when I can't wait overnight for the in floor to clean it.
    Jun 2007
    Arkansas
    88
    I must not need much. I only need to go up a few points. I may try to find a small measuring cup of some sort, and add a few oz's at a time
    Andy
    15' X 4' Round AG
