Results 1 to 11 of 11
Thread: Test results, please advise
    Mar 2014
    NW suburbs IL
    31
    I just completed the extensive tests on pool water.
    FC-2
    TC-2
    CC-2
    No change when adding R-002 or 3
    PH-7.8 a bit higher then normal
    TA-70
    CH-125
    CYA-30
    Pool is 87- 89 degrees and crystal clear do I really need to add 5# of baking soda (to raise TA) and a but load of calcium chloride (to raise CH) as indicated on chart? I will add acid to bring PH down a bit . All I have been doing is using liquid chlorine daily, a few tablets floating to help keep chlorine up and adding muratic acid as needed.
    Please advice
    Thank-you
    24' round AGP 54" recessed 2' in ground, 2hp 2 stage Hayward pump, 150 sq' filter
    Install on May 28 2014
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,655
    Re: Test results, please advise
    Your calcium level is fine for a vinyl lined pool.
    FC + CC = TC btw.
    Your TA level is fine if your PH is fairly stable.
    Smykowski's Avatar
    Sep 2011
    3,065
    Can you retest FC and CC for us?
    Oct 2013
    Chapin, SC
    1,141
    And tell us exactly how you're doing the test.
    Pool size: 24000gal inground Vinyl-Taylor k-2006 and k-1766 test kits and-speed stir
    Intermatic P1353ME digital timer w/freeze sensor
    CircuPool Si-45 SWCG System
    Polaris 280 vacuum/Polaris PB4-60 boost pump
    Pentair IntelliFlo VS 3hp Pump--Pentair sand filter
    Mar 2014
    NW suburbs IL
    31
    FC-3
    5 drops R-0001 and 0002
    Then 5 drops R-0003 TC-3
    Test kit then says subtract TC- FC=CC
    38,524
    That is the DPD chlorine test, not the recommended FAS-DPD Chlorine Test which is much more accurate.
    Mar 2014
    NW suburbs IL
    31
    It's not the chlorine I'm questioning
    Any comments on the calcium chloride recommended to raise CH
    Aug 2010
    Dallas, TX
    4,052
    Your CH is fine. You have a vinyl pool.
    Apr 2010
    East Texas
    9,655
    Quote Originally Posted by woodyp View Post
    FC + CC = TC btw.
    ..............my first post
    jcowart's Avatar
    Jun 2012
    Labelle, TX
    320
    Quote Originally Posted by Moonlite swim View Post
    FC-2
    TC-2
    CC-2
    TA-70
    CH-125
    CYA-30
    Please advice
    Thank-you
    Your FC is the lowest we recommend based off your CYA. We use a ratio for the FC/CYA. The higher the CYA is the higher the FC needs to be. With CYA at 30 your min is 2. Most pools see an average of 2ppm a day loss so a target of 4 to 5 is your best bet. Your TA should be fine at 70, at least for now. If you have wild swings with your pH then you can make a small adjustment with your TA. The TA is a buffer for your pH. You have a vinyl pool so calcium is really not needed. TFP recommends at least 50 and your already past that. Watch out for the pucks. They add both chlorine and CYA. For your pool that would be a little over 2ppm per 8oz puck. I also see you have the DPD test kit. What we recommend is the FAS-DPD kit. It will give you the accuracy with "higher than pool store" chlorine the TFP uses because of the FC/CYA relationship. You can order that kit from tftestkits.net and then have a full test kit. You can have a very clear trouble free pool if you follow advice here, but it's one or the other. TFP advice and pool store advice does not mix.
    17500 gallon Doughboy AGP, Hayward DE filter, waiting for the 1.5hp DB pump to go out.
    Learn to take the advice here and be trouble free or use the pool store's advice. "You can't do both and get very far"
    Administrator Leebo's Avatar
    Jul 2011
    Eastern Ohio
    7,110
    Moonlite,
    Can you please point us to what chart you are referring to? The Calcium level in vinyl pools does not matter at all......do not add ANY to match ANY level. Ignore it all together and pretend it doesn't exist. Your TA level works to help control your pH level. As long as you don't have any wild pH swings then I wouldn't worry about increasing your TA level at all. The only number that jumps out to me is your CYA level. Bumping that number up to 40ish will help you out in the long run by reducing the amount of chlorine the sun consumes per day.
