Thread: Strange Pool Light Problem w/ Timer
    Aug 2014
    GA
    3
    I have an LED pool light that has multiple different colors.
    You cycle through the available colors by simply turning the light off and then quickly on again.
    It has always worked perfectly, and it has always stayed locked on the color I leave it on.
    That is, until I replaced the simple toggle switch with an electronic timer so it would come on automatically for a few hours every night.
    Now it will stick on the one color for a while, and then change.
    It is completely random, sometimes it will stay on the preset color the entire time its on, other times it will change every 30 minutes or so.
    Power surges are the obvious answer, but there is no reason it should be getting power surges due to the switch change.
    There are no loose connections.
    Any ideas?
    Apr 2013
    Sacramento, CA
    2,769
    Re: Strange Pool Light Problem w/ Timer
    Switch to a mechanical timer.
    Aug 2014
    GA
    3
    Any recommendations?
    The only ones I have seen are huge contraptions, I would need one that would essentially wire in to a wall receptacle.
    ps0303's Avatar
    Jul 2011
    FL
    3,684
    Is the electronic timer made by Intermatic?
    Paul
    http://www.gastekservice.com A word of caution: When working with gas and electrical you might want to consider a licensed contractor. Consider the value of your life and others around you. If you would like to provide a review of the help I provided, please use the following link to leave a review. gastek - Google Search,
    Aug 2014
    GA
    3
    No, its made by Defiant.
    It's a Home Depot digital household timer mounted in a weatherproof enclosure.
    http://www.homedepot.com/p/Defiant-2...specifications
