Results 1 to 16 of 16
Thread: Calculating FC from SWG output
    Jul 2012
    Saugerties, NY
    447
    So I've been wondering just how much FC is produced by a typical SWG. I was able to find out that one of the SWGs we typically use produces 36 grams/hr. So if I convert that to ounces, I get about 1.3oz. If I plug this into the pool calculator, it says it equates to about 0.4 ppm FC. All of this is based on a 24,000 gallon pool (what I would consider "average" size) with CYA between 50 and 80 ppm. I'm assuming that 36 grams/hr is the maximum output. This seems kind of low. If a pool runs 12 hours/day, it would only generate 4.8 ppm FC in a day. Most of my pools run at 50% or less. So that would mean only 2.4 ppm FC is added in a day. So in order for these pools to maintain FC levels, they must only be losing 2.4 ppm or less.
    Is my math wrong, or do pools really only lose about 2 ppm FC in a day?
    TreeFiter
    Pool Technician
    Saugerties, NY
    aussieta's Avatar
    Jan 2014
    Langwarrin, Victoria, Australia
    488
    Re: Calculating FC from SWG output
    my cell is 25 grams per hour at 100% in 13,000 gallon pool
    2 hours at 100% equals 1ppm free chlorine for me
    1 run 8 hours at 100% in the middle of summer
    equals 4 ppm that is with lots of use and unfortunately the dog gets in to
    on your equation i would suggest the cell is too small for the pool
    SWG inground peanut shaped eco-bright concrete pool
    50,000 litres 13,000 gallons
    Lincoln Salt Chlorinator, 25 gram cell Sand Filter with glass media
    Taylor K2006-C test kit, Taylor K-1766 salt test, Dolphin M500 pool cleaner
    are you taking care of your pool or is the poolshop taking care of you
    38,354
    Your math sounds correct. My t15 puts out 1.4 lbs per day.
    A properly clean pool should normally only lose 2-4ppm each day.
    Jul 2012
    Saugerties, NY
    447
    I suppose I could test this out using the same principle behind the OCLT. Once the sun goes down, there should be no FC loss, so if I were to run the SWG overnight, I could find out how much the FC increased overnight, then divide it by how many hours it ran for to get the rate of FC/hr. Now I just need to figure out what pool I can try this on.
    Did you mean to say 1.4 oz?
    TreeFiter
    Pool Technician
    Saugerties, NY
    38,354
    No. The SWGs are rated in terms of pounds of chlorine gas.
    Also, the OCLT could acceptably have a FC loss of 1ppm, so that is going to skew your test.
    Oct 2013
    Chapin, SC
    1,141
    My circupool is rated at 2lbs which I've found to be pretty accurate I've developed a excel spreadsheet to determine approximately how much FC will be generated for 1-100 percent based on number of hours running time. Anyone interested in getting a copy of it just pm me with your email addy and I'll send it to you.
    Pool size: 24000gal inground Vinyl-Taylor k-2006 and k-1766 test kits and-speed stir
    Intermatic P1353ME digital timer w/freeze sensor
    CircuPool Si-45 SWCG System
    Polaris 280 vacuum/Polaris PB4-60 boost pump
    Pentair IntelliFlo VS 3hp Pump--Pentair sand filter
    Jul 2012
    Saugerties, NY
    447
    Hmmm...lbs/day makes sense, but the brochure for the Compupool Infinity series gave it as grams/hr. 36 grams/hr is a little over an ounce in 12 hrs, so it would be somewhere between 2 and 3 oz in a day. The brochure says the system is rated for something like up to 150,000 gallons. Maybe its a typo. I did find where the old systems were rated in lbs. The old systems we put on most of our pools, which typically range from 22,000 to 50,000 gallons are rated at 2.5lb.
    TreeFiter
    Pool Technician
    Saugerties, NY
    Oct 2013
    Chapin, SC
    1,141
    I doubt it'd be too difficult to convert grams to ozs to use in my spreadsheet if you're still interested. Just pm me your email addy.
    Mar 2007
    San Rafael, CA USA
    12,082
    Since 24,000 gallons is 90,850 liters, then (36 g/hr) * (1000 mg/g) / (90,850 liters) = 0.4 g/hr (ppm FC per hour) as you had calculated. Over an 8-hour day that's 3.2 ppm FC. In 150,000 gallons that would only be 0.5 ppm FC over 8 hours so too undersized during the day. They may be figuring running 24 hours for 1.5 ppm FC but that's still pretty slim and unlikely to keep up.
    Jul 2012
    Saugerties, NY
    447
    Quote Originally Posted by chem geek View Post
    I went back and looked at the brochure, and I realized its all in metric. It kind of makes sense that if they are giving grams/hr the volume would be in Liters. So it was 150,000 liters, which is somewhere around 40,000 gallons.
    TreeFiter
    Pool Technician
    Saugerties, NY
    mas985's Avatar
    Pleasanton, CA
    11,741
    36 grams/hr = 1.9 lbs/24 hr so fairly typical output for a SWG.
    Mark
    Mar 2007
    San Rafael, CA USA
    12,082
    And 150,000 liters and 36 g/hr would be 1.9 ppm FC over 8 hours so that sounds about right for a barely sized SWG which is why we recommend getting one with a volume claim that is 2-3 times your actual pool volume.
    Oct 2013
    Chapin, SC
    1,141
    Does anyone make a swg that outputs over 2lbs in a 24hr period? Compupool says theirs is 2.5, but I've not heard of anyone getting that kind of production. Even IC 60s are rated at 2.0 lbs/day
    Mar 2007
    San Rafael, CA USA
    12,082
    The AutoPilot Pool Pilot Professional strings up to 6 cells together for 15 pounds per day but that's still 2.5 pounds/day per cell at around $2000 per cell in a 6 cell system. The Saline Generating Systems (SGS) SG 5000 outputs 2.3 pounds per day for around $1500. The Hayward Saline C 6.0 Commercial Salt Chlorine Generator outputs 6 pounds per day but it's around $4000 (discounted).
    Oct 2013
    Chapin, SC
    1,141
    Thanks, was just wondering. That said, how can the IC 60 be rated for up to 60000 gal pools if the chlorine production is only 2lb/ 24 hr day? I guess technically, 4ppm every 24 hrs is sufficient?
    Mar 2007
    San Rafael, CA USA
    12,082
    Over 8 hours that would be 1.33 ppm FC and no that is not normally sufficient. The ratings that the SWG manufacturers give are barely on the edge and really would only be possible if one were using supplemental algaecide or phosphate removers. This is why we suggest oversizing the SWG by a factor of 2-3. It's also more economical since the price is not proportional to SWG output, at least for the residential units. So the IC60 would be more appropriate for a pool up to 30000 gallons and would be economical for a 20000 gallon pool since the cell will last longer compared to a unit rated for up to 40000 gallons.
