Thread: SWG acceptable levels
    Aug 2014
    Phoenix, AZ
    5
    So my salt cell wasn't calibrated and gave me an extremely low read out on my salt level. With that, I added salt. My new SWG and Leslies said I have a salt level of 5000ppm. Is keeping this level (cuz I don't want to drain 33% of my pool) acceptable? Or should I drain it?
    Aug 2010
    Dallas, TX
    4,052
    Re: SWG acceptable levels
    Depends on the SWG.
    That said, I would not trust Leslie's test results. If your SWG is happy, leave it be. If it reports high salt, again it depends on the SWG brand as to whether you need to drain or not - if your salt is actually 5000 ppm.
    I highly recommend this test kit for testing salt. I have found it to be far more accurate than strips.
    http://tftestkits.net/K-1766-Taylor-Salt-Test-p31.html
    It isn't cheap, but it works.
    Aug 2014
    Phoenix, AZ
    5
    Thanks for the test kit recommendation. Well, Leslies and my new SWG coincide. So I gotta believe the 5000ppm. The SWG is a T-9 cell with at 2700 to 3400 ppm recommendation. Thinking I'm gonna have to drain.
    New Brunswick Canada
    819
    Depending on what type of SWCG you have, you can go through a recalibration. Use silver nitrate to really know where your readings are. If they tested with a meter, remember meters go out of synch almost weekly and you are dependent on them recalibrating them.
    If its an Aqua rite, you can quickly google how to reset it to the proper salt level.
    38,521
    You can not calibrate the Hayward SWGs.
