Thread: Plumbing advice
    Jun 2014
    Montreal, Canada
    6
    Plumbing advice
    Hi evebody,
    I'm in the process to rethink all the composant of my pool. At this point I have few of them:
    - Jandy CL460 filter
    - ecopump EP1 2 speed 0.75/1.25HP
    - new vinyl liner 15x24
    I'm about to buy:
    - 2" flex pipes
    - 1 x Jandy diverter 3 ports 2/2.5" (model #4717)
    - 4 x Jandy 2 port valve 2/2.5" (model 4716)
    - some unions
    Result of my thinking is represented here:
    What do you think? Is the hardpipe plump is a better option?
    Thank you guys
    Oval AG vinyl 15x24, 4 feet depth, around 10K gal, 1.25 true HP 2 speed EcoPump EP-1 50 GPM, filter (trying to figure out which one), chlorine feeder
    38,475
    Re: Plumbing advice
    Hard plumbing is certainly a better option if possible.
    Why do you have so many valves on the suction side? You could just have the single 3-way valve (BTW, much better to have the common pipe in the middle port, in this case, make the middle port go to the pump).
    If you just need to shut the flow for cleaning the pump/filter, then #3 would be sufficient and save $100 by not getting #1 and #2.
    Jun 2014
    Montreal, Canada
    6
    Re: Plumbing advice
    Hi Jason,
    Thank you for the response. for the suction part, I've put valve 1 and 2 just in case I have to service the 3 port valve. Next question I had in mind while doing this: how often the 3 port valve need to be serviced? not so often so valves 1 and 2 can go
    thank you for your suggestion!!
    38,475
    Re: Plumbing advice
    The valve should not hardly ever need servicing. What would you do when you have to "service" the 2 way valves?
    It is easy to plug the skimmer/vac port and cover the floor drain.
    Jun 2014
    Montreal, Canada
    6
    Re: Plumbing advice
    oh I see!!!! so valve 1 and 2 are out!
    Few thing to buy and I'm ready for the installation.
    Thank you Jason for the advices!
    Jun 2013
    East TN
    309
    Re: Plumbing advice
    We used to have a flex pipe from the filter to the return and it would shake the metal where the return fitting goes. After pvc plumbing it doesnt shake. Ours is 1.5" pipe.
    18,000 Gallon Aboveground. Sand Filter with 2HP 2 speed Pump.
