Thread: SWG percentage
    aussieta's Avatar
    Jan 2014
    Langwarrin, Victoria, Australia
    490
    SWG percentage
    Hi, trying to get my head around how the percentage factor works on a SWG
    I thought either the voltage or the amps were reduced to the indicated percentage
    i have been too busy to dismantle control box and measure but i do intend to
    i made a post stating that is how they worked,
    fortunately a mod picked up that it was wrong and deleted it
    after reading as many post as i can find
    it appears that it is a time based percentage, ie 70 percent of one hour
    the reason i assumed it was electrically controlled is that if i have high salt and set to 100% i get an error
    but at 99% it is all ok
    are there different styles that are controlled by varying electrical amps/volts
    any more info or sources of information greatly appreciated
    thanks,
    Andrew
    SWG inground peanut shaped eco-bright concrete pool
    50,000 litres 13,000 gallons
    Lincoln Salt Chlorinator, 25 gram cell Sand Filter with glass media
    Taylor K2006-C test kit, Taylor K-1766 salt test, Dolphin M500 pool cleaner
    are you taking care of your pool or is the poolshop taking care of you
    38,521
    Re: SWG percentage
    Most SWGs are a % of time the SWG in generating over some period of time (I have seen reports or anything between 30 minutes and 200 minutes ... varies by manufacturer). I think there are some (maybe more common down there) that actually do somehow vary the output, but I know very little about them beyond that they exist.
    aussieta's Avatar
    Jan 2014
    490
    Re: SWG percentage
    thanks Jason
