Thread: How to measure high FC level
    I'm shocking my pool and the FC should be around 17, but my test kit only has a scale from .5-5. How do i know if it reaches 17?
    Firefly2000's Avatar
    Jul 2008
    Sydney, Australia
    38
    Re: How to measure high FC level
    Birch,
    Unfortunately you'll need a better test kit that can test for much higher levels. The one recommended around here is the TF100 kit. Check out http://www.troublefreepool.com/categ...kit_comparison for more information.
    Hope this helps.
    Daniel
    47000L (12500 gal)
    IG Quartzon Interior
    Rolachem Acid & Chlorine dosing
    Paramount In-floor cleaner
    1.5HP pump + Sand filter
    Solar heating under the great Aussie sun!
    By far the best solution is to get a FAS-DPD chlorine test, which comes in the better test kits.
    However you can get a vague idea of your current FC level by diluting one part of pool water with three parts of distilled water (or other water without any chlorine in it), test that, and multiply the result by four. You lose a substantial amount of precision, with dilution the result is +-6 or worse, but you can get some idea of what your current level is.
    Thanks, i bought the recommended leslie kit FAS-DPD but it only measures from .5-5 fc.
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Quote Originally Posted by birch
    You bought the Leslies DPD kit, that's different than the FAS-DPD. The FAS-DPD measures up to 50. TF-100 sells it for about $23.00.
