Thread: Target ta
    May 2014
    Gaffney, SC
    16
    Target ta
    Pool math says a range from 70 to 90+
    what target TA should I shoot for?
    Went a way for 10 days with a floater from Wally's came back & TA is way low.
    FC 3.5
    TC 3.5
    PH 7.3
    TA 50
    CYA 40
    Have been using the TFPC meathod all season, everything is crystal clear.
    Thanks.
    13.5 k gallon, AG Swim n' Play Inc. Islamorda 24 ft. round , Pentair Dynamo 1.5 HP Pump, Pentair Sand Dollar SD40 sand filter 40GPM.
    Install 5/20/14
    38,301
    Re: Target ta
    Are you going to continue using pucks? If so, then you should raise the TA to around 100ppm. If you are switching back to bleach, then 70-80ppm would be fine.
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: Target ta
    TA a subjective level. If your pH stays stable where is at, I'd say leave it maybe raise a bit. If it was stable at your previous level, raise it to there. Also depends on your CSI with the lower TA.
    Mobile post. Beware of brevity and spelling errors!
    Isolated Spa - 345 Gallons
    May 2014
    Gaffney, SC
    16
    Re: Target ta
    Back to bleach for sure! Thanks.
    Install 5/20/14
