Thread: Solar Cover Removal - Solar Roller
    Mandolina's Avatar
    Apr 2014
    Los Angeles USA
    67
    For our Intex 16 foot above ground, round pool with no deck, and very little storage space, my husband and I decided to go with the Solar Roller Coverstick, by SolarFacory, to remove our solar cover. It has worked very well for us, we use it, once or twice a day, everyday. The attachment instructions were a bit confusing, and my husband had to to drill an extra hole in one aluminum tubes to make the attachment a little more secure. We have a saltwater pool and the aluminum roller is starting to get some saltwater corrosion, the white mineral deposits, but I think it will hold up for some time and if it doesn't, we have more poles that came with the kit. The removal of the cover can be done by one person and I have done it myself, but it is easier with two persons on this four foot high pool, as one person holds one end, of the rolled cover up high so the excess water will drain back into the pool, while the second person hold the other end just above the water's surface. This process gets rid of quite a bit of excess water trapped in the roll and makes the cover very light for easy lifting, over the pool, to the storage area.
    I saw another post where someone made a roller out of pvc pipe and attached the cover with plastic screws, which sounds like a good alternative for a small pool. The Solar Roller Coverstick comes with an aluminum crank handle which makes the rolling very fast and easy. I made the YouTube video with my iPhone photos and the app "PhotoMotion"
    http://youtu.be/l3qd7m2kdeY
    16' x 48" 5000 gal. Intex Ultra Frame AG Pool, Los Angeles, CA
    Hayward Full-Flow Cartridge Filter System with 2 Speed Power-Flo Matrix Pump,
    Intex SWG, Intex Wall Mount Surface Skimmer, Solar cover & Solar Roller,
    Confer Plastics A-Frame 7200 Adjustable Roll-Guard Safety Ladder,
    Kokido SkoobaMax Vac, Custom Canine entry & exit ramps,
    Jul 2014
    Bastrop, Louisiana
    199
    Re: Solar Cover Removal - Solar Roller
    Just a thought, but to keep the poles from getting eaten up by the salt water, you could put a "PVC sleeve" over the aluminum tube and use one bolt at the end opposite the crank handle going through the PVC and the aluminum tube. The salt water wouldn't get to the aluminum then and your cover might last for a good long time.
    Randy H.
    Intex 18' X 48"
    G.A.M.E. Sandpro 75 Sand Filter (Single Speed 3/4 HP, 75 lbs sand, 2650 GPH, 7-way valve)
    mas985's Avatar
    Pleasanton, CA
    11,737
    I had the same problem with the aluminum poles so I built my own poles out of ABS:
    http://www.troublefreepool.com/threa...r-Cover-Roller
    Mark
    Mandolina's Avatar
    Apr 2014
    Los Angeles USA
    67
    Quote Originally Posted by one_knight4u View Post
    'Just getting back to forum for the new swim season. Yes the salt water did corrode the aluminum pipe. I have another set of pipe that I will use this season. I was told by David Hoff, the inventor, to coat the pipe with clear Rust-oleum spray paint, which we did, but 'haven't used them yet. I have some shrink wrap sleeves I may add that as well - is that what you are referring to regarding the "PVC Sleeve"?
    Mandolina's Avatar
    Apr 2014
    Los Angeles USA
    67
    Quote Originally Posted by mas985 View Post
    That's a good idea! I'll probably go that route when my newly protected aluminum poles wear out.
    jmcdtucson's Avatar
    Jun 2014
    317
    That's a neat gizmo, thanks for posting? I'm still pulling off by hand though I did build a PVC saddle to store it on.
    Intex 12'x24'x52"
    8,403 gallons
    Intex SF60110 2450 GPH Sand Filter
    Intex CS8110 SWG
    Aquabot AJET121I Pool Rover S20-40
