Thread: Easytouch with VS pump not shutting off when schedule ends
    Jun 2011
    Fullerton, CA
    31
    I'm having a problem that started a few days ago. I'm running a VS pump with an Easytouch. It has been running fine for since installed 3 years ago. Now when the schedule pass the end time, the pump doesn't stop. It continues to run. I can put the system in Service/Timeout mode and the pump stops. When I go back to Auto mode, the pump starts again. Am I having a problem with the relay? Or what else can I check?
    Thanks in advance.
    Jun 2011
    Fullerton, CA
    31
    Re: Easytouch with VS pump not shutting off when schedule ends
    One more pice of information. This morning I switched from Service/Timout mode back to normal and the pump did not start. I'll wait and see if the schedule will start it again.
    Jun 2011
    Fullerton, CA
    31
    The pump started running at the scheduled start time. I ran the self-diagnostic test last night (in the dark) and it gave error code 14, LCD backlight and Switch (buttons). Not sure if this was due to incorrect button press. I was going to run it again today, and now see that the pump has shut off. Go figure. I will monitor for the next few days to see if this holds.
    Jun 2011
    Fullerton, CA
    31
    It was working fine for a few days, but today the pump wouldn't start. I'm going to order a new relay!
