Results 1 to 12 of 12
Thread: burning eyes
    Jul 2014
    St. Simons Island, GA
    172
    burning eyes
    I don't understand why my eyes are burning, both b4 and after a really hard, long rain that overfilled the pool. After rain test results are: FC 4.5, combined chlorine (calcium carbonate) 0, pH 7.6, TA 80, borate 50. didn't test CYA but it was about 90 about a week ago. As for salt level, the SWCG is happy. Water is clear and feels great!
    Any ideas?
    Home pool: Intex 11,400 gallon AG vinyl pool with sand filter & SWG. Taylor K-2006 test kit - coastal Georgia. I'm also in charge of the Elk's Lodge Pool, which is 55,000 gallons in-ground concrete with sand filter, 2 HP Hayward pump, currently using tri-chlor pucks and cal-hypo system.
    peterdaly's Avatar
    Aug 2013
    Fayetteville, NY
    188
    Re: burning eyes
    Has your pH changed from the rain?
    Fayetteville, NY -17K gal, IG vinyl, Hayward SP2300VSP Max-Flo Variable Speed Pump, FlowVis Flow Meter, Sand filter
    Self designed Arduino powered automation for pump and solar control, Solar Attic Pool Heater, AutoPilot Digital SWG, TF100
    Jun 2011
    Long Beach, CA
    2,784
    Re: burning eyes
    Are you using sunscreen? Some types of sunscreen cause my eyes to burn.
    Jul 2014
    172
    Re: burning eyes
    pH was tested after it rained. Used sunscreen about 7 hours earlier, but sweated it off while fishing. Jumped in water to cool off after fishing.
    30,419
    Re: burning eyes
    And?
    Jun 2011
    Long Beach, CA
    2,784
    Re: burning eyes
    From those numbers your eyes should not be having burning issues, unless you have them open a lot. All water will effect the eyes if they are opened long enough underwater. As you posted, the rainwater had nothing to do with it and the water is balanced chemical wise.
    Do you still have the burning today?
    Aug 2010
    Dallas, TX
    4,052
    Re: burning eyes
    Hey, let's make sure these test results are right. CC is combined chlorine, but you said it was calcium carbonate. Calcium is CH.
    Administrator Leebo's Avatar
    Jul 2011
    Eastern Ohio
    7,086
    Re: burning eyes
    Vince-1961,
    I'd like to start off by welcoming to the forum! I hope we can figure out this issue for you.
    For starters, let's verify a few quick questions.
    • What are you using to test your pool with?
    • You state your CC is zero, with clear water. Can you please post a photo?
    • When your eye's start burning........how long have you been in the water?
    Jul 2014
    172
    Re: burning eyes
    Duraleigh, ph tested at 7.6 after the rain per the original post.
    ping, I didn't get in pool today as I am just now getting home.
    RobbieH, the instructions on the inside of the lid of the taylor K-2006 test kit says to record
    combined chlorine as "calcium carbonate". I thought that was an odd instruction, but ...hey....whatever.
    Leebo, Taylor k-2006 is test kit. It's dark now, so no photo. I was not underwater very long at all. 3, maybe 4 dunks with eyes open. Otherwise, my eyes were out of the water. The entire swim was less than 20 minutes.
    I'll run tests tomorrow morning and maybe get a photo or even get in and open eyes underwater if I have time.
    peterdaly's Avatar
    Aug 2013
    Fayetteville, NY
    188
    Re: burning eyes
    Do you know what your pH usually tests at? One of the things many of us seem to be dancing around is that whatever the pH was after the rain, is it much different than the level before the rain?
    Regardless of number, if it changed, then that's one potential cause.
    Anther question, related to combined chlorine...do you smell more of a chlorine smell than usual? Regardless of test results, if you smell more chlorine smell, that's an indication of CC, which can sting eyes. Even it is or was present, there are some reasons why if might not have been in your test sample, leading to a 0 CC test.
    I am pretty sure I got that right...I just went through this myself, and am somewhat parroting what i was told a week or two ago.
    Smykowski's Avatar
    Sep 2011
    3,065
    Re: burning eyes
    Quote Originally Posted by peterdaly View Post
    Yep, that's all correct.
    n240sxguy's Avatar
    May 2014
    Benton, KY
    1,801
    Re: burning eyes
    If it's any consolation, sometimes my eyes burn a little after I am out of my pool for a bit. I have my eyes open a LOT underwater while I'm swimming. I haven't found any correlation between my chemistry and my eyes. Maybe it's just the amount of contact my eyes have with the water that varies from one swim session to the next. We've only had the pool for two months, so maybe eventually I'll discover the correlation. Maybe it is ph. I keep it 7.4-7.7 always.
    30K gallon IG vinyl. 1.5HP 2-speed Waterway Mustang pump. 600 lb sand filter. Polaris 280. Circupool SI-60+. TF-100
