Thread: Is the Intellichor "off"?
    coog61's Avatar
    Nov 2009
    Richmond, TX
    84
    While Slamming I want to turn the Intellichor off. From the control panel I set "engage" to "no". But the lights on the cell which indicate the cell is working and the Cl output are still on for more than a day. Is this producing Cl or not?
    17,500 Gallon, SWG 33' x 21' freeform w/ Sunstone Cobalt Plaster. Attached 6 X 6 Spa raised 12" w/ 6 Jets with Moss Rock Spillover. 25' Moss Rock Waterfall. Pentair Intelliflo VS-3050 for Pool, 2 HP Whisperflo for Waterfall, Pentair Clean & Clear Cartridge 320, Pentair 400K BTU Max-E-Therm heater, Pentair Intellichor, Pentair EasyTouch 4P, Pentair Legend Platinum Cleaner w/ 3/4 hp pump, autofill system, nat gas fire pit. BBB convert
    http://www.troublefreepool.com/new-tx-pool-t17907.html
    gatorbrit's Avatar
    Aug 2013
    Raleigh,NC
    95
    Re: Is the Intellichor "off"?
    I don't know, but can't you just push the down button on the IC to shut it off - the button that controls the amount of CL production?
    18k vinyl IGP, Sand Filter, EasyTouch Control Sys, Pentair Intelliflo, Intellichlor IC 40 SWG, Rheem Heat Pump.
    susa's Avatar
    Oct 2010
    Deep South
    578
    simply disconnect the plug to the Transformer
    Ksnewman's Avatar
    May 2012
    Middle Tennessee
    173
    Set your IC to 0%. I have remote and can do this as well as at the panel.
    18x36 kidney 20,000 gallons IG vinyl. Pentair Easy Touch 8 w/IntelliChlor IC40. Triton II TR100. Pentair Intellifllo Variable Speed. Waterfall/Jump Rock. 2 Pentair Intellibrite lights. TF-100 Test Kit. And a very happy husband who gets to play in the pool without having to take care of it.
    coog61's Avatar
    Nov 2009
    Richmond, TX
    84
    Thanks. I did this but the lights showing the producing % on the SwG are still on. I unplugged the power and wrapped the end in plastic.
