Thread: Cleaning pump strainer
    coog61's Avatar
    Nov 2009
    Richmond, TX
    84
    When cleaning the pump strainer, after the pressure on the filter drum is bleed, most the debris runs back toward the pool. Then after filling the basket with hose water and restarting the pump, the debris flows back into the pump strainer. Any tips on how to collect this stuff?
    17,500 Gallon, SWG 33' x 21' freeform w/ Sunstone Cobalt Plaster. Attached 6 X 6 Spa raised 12" w/ 6 Jets with Moss Rock Spillover. 25' Moss Rock Waterfall. Pentair Intelliflo VS-3050 for Pool, 2 HP Whisperflo for Waterfall, Pentair Clean & Clear Cartridge 320, Pentair 400K BTU Max-E-Therm heater, Pentair Intellichor, Pentair EasyTouch 4P, Pentair Legend Platinum Cleaner w/ 3/4 hp pump, autofill system, nat gas fire pit. BBB convert
    http://www.troublefreepool.com/new-tx-pool-t17907.html
    38,290
    Re: Cleaning pump strainer
    There is not reason to drain the filter or open the air valve. Just take the pump lid off and lift out the basket. If you are quick, then most of the debris should not flow anywhere.
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,602
    A cheapie minnow dip net is your friend if need be. I keep one hanging on my skimmer basket.
    coog61's Avatar
    Nov 2009
    Richmond, TX
    84
    When I shut off the pump there is still ~ 3 psi in the system. It does not seem safe to remove the pump basket under pressure. What am I missing?
    coog61's Avatar
    Nov 2009
    Richmond, TX
    84
    Sorry. .... My bad. The gauge was stuck. Lid came off .. No problem.
    38,290
    You got it. Time for a new gauge. The liquid filled from tftestkits.net are very nice and last longer.
