Results 1 to 8 of 8
Thread: What is my shock level supposed to be?
    Jul 2007
    Ohio
    47
    My pool has been sparkling clear all summer, I have been just tweaking my Autopilot setting keeping between 3-5 FC levels, and all has been well. 5 days ago it got cloudy, I shocked it (15) but didn't keep it there though, and today it is still cloudy. I thought my shock level was 15, but am I using the Pool Calculator right? It is saying 23 is my shock level? Here are my numbers:
    FC - 3.5
    TC - 3.5
    PH - 7.6ish
    TA - 100
    CYA - not sure, out of reagent, it was 60 on 8/2 and I added about 2 lbs of CYA
    Temp 86
    It may have started to get cloudy when I added the CYA... not positive though.
    So is it really 23? If so, I will get it up there and get this thing cleaned up!
    Thanks, Chuck
    16X24X40 Grecian L Vinyl Pool - Dig 9/4/2007 and first swim 9/21/2007
    Located in Ohio Approx 27K gallons
    Pentair Whisperflow 1 HP 2-speed Pump
    Hayward Sand Filter Jandy AE2500 Heat Pump
    Autopilot Dig-220 w/sc-60 cell
    Re: What is my shock level supposed to be?
    2 lbs of CYA in 27,000 gallons would raise the CYA level by almost 10. If it was 60 before, then it should be about 70 now.
    With a CYA level of 70, your shock level is around 20.
    Jul 2007
    Ohio
    47
    Jason, thank you very much. I am getting used to the calculator, it is a great tool.
    --Chuck
    Hi Chuck1971
    I am new here, and I am reading through this and I mean no direspect, I am trying to learn so I can understand for my own sake. My question is why would you add CYA if your level was 60? What am I missing?
    by the way-1971 was a great year!
    Sharkline 18x33 54"AG, Hayward 1.5hp Perflex D.E., TF-100 test kit
    Finally....a pool of our own!
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Quote Originally Posted by kidsluv2swim
    Hi Chuck1971
    Recommended CYA levels for a SWCG is 60-80 ppm
    MikeInTN's Avatar
    Middle Tennessee
    1,335
    Dangit FPM, you beat me to it!
    Although I'll add that the higher CYA level helps prolong the life of the SWCG cell.
    24' x 52" AGP - approx 13,500 gallons
    Pentair Optiflo 1 hp/2sp pump w/ Swimpro Voyager 150 sq ft cartridge filter
    Intex 8110 SWCG
    "Fear the Schnauz!"
    Jul 2007
    Ohio
    47
    Exactly... See I can read and learn how to do this correctly!!!!
    I bought the largest cell possible for the SWG also, knowing it should last longer.
    --Chuck
    You guys know everything, that is why I love this forum!
