Thread: CYA at 0 TA 40 what do I fix first?
    Joe_Fire's Avatar
    Sep 2012
    South Florida
    8
    My parents have a newly resurfaced plaster pool (well a little less than a year).
    Running a Hayward SWG.
    My brother has been keeping an eye on the PH, salt and Chlorine but not anything else. After hearing reports of bubbles on the pool walls
    I stopped by yesterday with my TFT100 to do a thorough exam.
    The Results
    Aprox 15000 Gallons
    FC 1
    PH 8.5 (I added 18oz of acid it should be ok now)
    TA 40
    CH 390
    CYA 0
    Salt 3200
    Water temp 93
    Pool is in south FL and it's been very hot the last week or so.
    Should I go right for the CYA and Worry about raising the TA after?
    Or do the TA first?
    Or both at the same time.
    BTW the water looks fine,clear no algae. But the SWG is set at 100% pump running 9 hours a day
    16K Free Form Diamond Brite, 8' sunshelf,deckjets,and bubbler,Travertine pavers
    Hayward C17502 Cartridge Filter, 2HP Variable pump, Turbocell T-Cell 15 SWG, Aquaplus controller
    38,516
    Re: CYA at 0 TA 40 what do I fix first?
    Raise the TA to about 70 and start the CYA dissolving in a sock at the same time.
    Joe_Fire's Avatar
    Sep 2012
    South Florida
    8
    Thank you. On my way to the store
