Thread: Pressure for Polaris 280
    Apr 2014
    Spring, TX
    3
    Does anyone know what pressure PSI should be output by booster pump to return line to run Polaris 280.
    Thanks
    DFS
    Mar 2007
    San Rafael, CA USA
    12,082
    Re: Pressure for Polaris 280
    I am sorry no one responded earlier. This fact sheet says that the Polaris 180, 280, and 380 need 28-32 PSI and that the 180 and 280 need 12 GPM while the 380 needs 15 GPM. All three should have wheel RPM of 28-32.
    malcolmb5325's Avatar
    Sep 2009
    Sydney, Australia
    166
    rule of thumb is 1 rev of the wheels = 1 psi.
    16,000lts Fibreglass, Magna Mineral Pool Water
    Jandy CV340 Cartridge filter, Zodiac TRi SWC, Z4 iAqualink, Jandy Laminar Jets, Solar Heating, Spa Jets with Jandy 1.5hp Epump operating everything.
    CUTiger78's Avatar
    May 2009
    NoVA
    460
    Quote Originally Posted by malcolmb5325 View Post
    That's an interesting ROT, Malcomb. For years, my 380, w/ no restrictors installed, has turned at ~16 RPM. Works OK, but I guess it could be better. Got any idea how to troubleshoot the low PSI?
    Thanks!
    36K gallon 42X22 gunite/plaster kidney-shaped IG;
    1 hp Hayward Super Pump (new in 2012);
    Hayward S244T sand filter w/ Zeosand (both new in 2009);
    175K BTU LAARS Lite2 LG natural gas heater; Polaris 380;
    TF-100 test kit.
    Sep 2009
    Sydney, Australia
    166
    this is a start.......what size booster pump are you running? you need a minimum of 8gpm's for the cleaner flow. what size pipe? how far is the pipe run from booster pump to wall fitting? do you have pictures of the installation? no water bypass at the backup valve? no water bypass around the wall fitting or hose swivels?
