Results 1 to 15 of 15
Thread: Suggestions on how to cut deck boards
    yostmatt's Avatar
    Jun 2014
    Hollidaysburg, PA
    174
    I am trying to figure out the best way to cut my deck boards so they line up with the edge of the pool wall. In Hindsight I should of marked each one on the bottom, cut then flipped. Since I am past that point I am looking for some suggestions. I was thinking about having my wife stand in the middle with a rod with string attached and then mark side to side, then draw a line on the deck boards. But there is a little bit of human error involved there.
    Pics
    [IMG][/IMG]
    [IMG][/IMG]
    Time for some breakfast. Thanks in advance.
    ~Matt~ Radiant Metric 24'x52" 14k- built into a slope. CircuPool Si-30 SWCG. Jandy 200 SqFt cartridge filter. Pentair Optiflow 2-speed 1HP pump. Wanda the Whale. TF-100 Test Kit. Hard Plumbed.
    My Build w/ lots of pics
    Mod Squad pooldv's Avatar
    DFW, TX
    24,485
    Re: Suggestions on how to cut deck boards
    Yes, I think that is best. Maybe have her hold a deckboard cut to the radius of the pool against the framing for her to hold to help keep the string in the right spot. Since you only get one chance! Good luck!
    txnole's Avatar
    Aug 2014
    Amelia Island, FL
    544
    #1 would be unscrew the boards and make the cuts. That's your highest likelihood for success.
    #2 if this is a true circular pool, then you could use a string from the exact center of the pool. This would be the same as using a compass (the two point kind, not the directional kind). Put a pencil and a string level on the end of the string and mark the curve. This method has some potential for error, depending on where center truly is and any slope.
    #3 would be to attach craft paper or similar to the underside of the boards and transfer the pattern of the pool. This has some potential for error. Attach a pencil to the interior of a 1" PVC pipe. Run the pipe along the interior of the pool surround to transfer the pattern with the pencil. Remove the paper and invert to make your cuts. Again, this method has some potential for error.
    Also, if you want to "bend" your boards around the perimeter of the pool rather than using smaller straight boards as you did on the upper deck, set your saw depth to 50-60% of the wood height and make a large number of cuts along the backside! every 1"-2". This will allow the board to bend but still have enough rigidity to serve as your fascia and you'll have one long board with the right bends rather than 5-6 short boards. For more info, google KERF CUTS.
    yostmatt's Avatar
    Jun 2014
    Hollidaysburg, PA
    174
    Thanks for the suggestions.
    I could probably tie a could strings together, then in the middle should cold stand with a piece of rebar where the strings intersect...
    While I was at breakfast, I was thinking about this again. I wonder if I could make something up like a big C. The top of the C would hold a pencil, the bottom of the C I could run along the inside of the pool. humm.
    DFW, TX
    24,485
    First idea sounds pretty good. Second idea sounds hard. Go with the first one.
    Jul 2014
    Medina, Ohio
    55
    If you can see down between the boards, then you should be able to use a pencil and strike an arc across each board to make cut-off lines that will leave you a few inches of board overhang. Then make the first cut(s) with a jig saw (or a sawzall if you're good with one) to remove the long ends.
    Then, make a jig to slide along the inside edge of the top of the pool wall under the rough cut edge of the deck boards. Make this jig the length of the amount of deck board overhang you want, then attach a pencil to it and slide it around the pool wall so you will get an exact copy of the arc transcribed onto the top of the boards.
    Then make you final cuts nice and slow, file your edge a little, and you're done.
    17,100 gallon, 27' round Wine Barrel, Hayward Matrix 1.5HP 2-speed Pump, Hayward Pro Series 24" Sand Filter, Hayward Skimmer and Returns, TF100 test kit......and lots of labor!
    Nov 2013
    Fort Worth, TX
    114
    If you are trying to get the boards flush with the trim piece, you can cut the boards slightly long (i.e. 1/16") and then use a router with a pattern bit to follow the trim piece. Using this method, you will have perfectly flush boards.
    30,000 plaster in-ground pool with spa; 2.5HP single speed Centurion pump; Raypak RP2100 propane heater; Polaris 280 with pump, waterfall with separate pump, Triton II commercial sand filter; TF-100 test kit w/ SpeedStir
    Router with flush trim bit is absolutely the best way to go....
    20x40 IG Vinyl 35k gal, Hayward 24" Sand filter, Built fall of 2013, Single Speed Jandy 1.5hp Pump, Southwest Part of MI
    Using Tapatalk
    yostmatt's Avatar
    Jun 2014
    Hollidaysburg, PA
    174
    Quote Originally Posted by Billrector View Post
    So what you are saying is stand in the pool and run the router upside down along the pool coping?
    yostmatt's Avatar
    Jun 2014
    Hollidaysburg, PA
    174
    Quote Originally Posted by Augie56 View Post
    I I think I like this method.
    I grabbed a sheet of cardboard before I left work and went to an open end of the pool and taped it to the pool edge and traced a line on the cardboard. I cut it along the line, and took it to the deck. I traced the line three times, I am able to see down between a few of the deck boards. So I lined it up and drew my line. I didn't cut anything tonight. Wanted to think about it some more to see if there was a way to make it a little more precise. Plus the old adage of measure twice, cut once.
    After I get it cut, I was thinking about using the router to put a little round edge on the top of the deck board.
    Nov 2013
    Fort Worth, TX
    114
    Quote Originally Posted by yostmatt View Post
    No, you would run the router from the top after you rough cut the boards a little long. The pattern bit will follow any "pattern" including your pool trim. If you already have a router, this will give you perfect results, assuming you want the boards flush with the trim. This method will not work if you want the boards to overhang the trim.
    May 2012
    Montville NJ
    545
    If he wants the boards to overhang the trim, he could always screw a strip of luan (or those plastic lattice strips work well, and are a lot cheaper) onto the facia, let the bearing on the bit run on that, and then remove the luan afterwards.
    I agree, the best way to make this look good is to cut the boards a bit long with a jigsaw, then do the final pass with a pattern bit in a router (the clean all of the sawdust out of your pool)
    -dave
    27' Round ABG (17,000 gal) - +/- 11 hours of full sun per day
    Hard plumbed Hayward Perflex EC-40 DE filter w/ 1 HP pump (Got a new one June 2015)
    Filered 4 hours per day (on a timer)
    Pentair Aqualuminator - now working - and now dead once again, this time for good.
    Zodiac Wahoo
    Jul 2014
    Medina, Ohio
    55
    Yes, not matter how you do it, be ready for sawdust everywhere!
    You're idea of using the traced-curve cardboard piece(s) to transcribe the pool wall arc onto the boards you will be cutting seems about the easiest. Any small differences in the curve's radius (because every pool is not EXACTLY round) won't be noticeable because you're boards are overhanging the wall a little bit, too.
    Routing the curved edges after making your cuts will leave it looking nice, too.
    Get 'er done!
    Apr 2013
    Battle Creek, MI
    298
    By all means, DO NOT stand in the pool to operate the router! I might have missed it, but do you want the arc flush with the inside radius of the pool or the outside radius?
    18'x4' AG Intex Ultra Frame, 6,700 gal., assembled new 2013; Mods: Hayward EC50C90 Perflex filter & 1 h.p. PowerFlo Matrix pump, Fiber Clear cellulose D.E. substitute, Hayward H100ID1 100,000 BTU NG heater, a pair of 2'x20' Sungrabber solar heaters via the original Intex 635T pump, grey Hydro Tools through-the-wall skimmer, Confer steps/ladder system & Cover Free chemical pool cover. The Summer of Mods!
    Jun 2013
    SpringHill FL
    415
    +1 on useing a router for 100% professional result
    Nathan
    15x30 gunite 18k gallons Hayward star clear plus 120sqft cart
