Thread: Round "RUST spots" popping up everywhere. Can't remove with brush or scraper.
    Hi there,
    I've finally gotten a handle on my pool chemistry but now these little reddish brown circles have started popping up all over the pool. They are about 1/8in diameter, and I can't vaccum, brush, scrube, or scrape them off.
    They seem to be multiplying. I have a fiberglass pool, so I doubt they are rust.
    Any ideas?
    Here is a pictures
    https://drive.google.com/file/d/0Bzl...it?usp=sharing
    Edgewater, FL
    6000 Gallon In-Ground Fiberglass Bean shaped pool
    Hayward Cartridge Filter
    Butterfly's Avatar
    South Carolina
    10,045
    Re: Round "RUST spots" popping up everywhere. Can't remove with brush or scraper.
    Test to see if they are organic or metal stains.
    Post a full set of test results for us
    You're done SLAMing when:
    How would I test to see if they are organic or metal if I can't scrape anything off?
    Quote Originally Posted by Butterfly View Post
    Edgewater, FL
    Jul 2013
    Gilbert, Az
    116
    For organic rub a cl puck, for metal rub with vitamin c tablets from the vitamin section
    12k - free form - plaster- Nautilus fns48 DE filter- centurion 1hp (so quiet)- In floor cleaning system with Jandy Caretaker - TF-50 and 5 in 1 test kit, Phoenix, Az
