Thread: Cloudy water all of a sudden
    Oct 2013
    Mount Juliet TN
    8
    Pool has been clear all summer long, but in the last few days starting to look a little cloudy. Just took readings below.
    FC -- 4
    CC -- 0
    PH -- 7.6
    CYA -- 55
    TA -- 90
    I use SWG system and supplement with Liquid Bleach when needed. Tuesday of this week they started construction on 3 lots near my house and now have 3 open lots near my house with dirt piles. I'm not sure if the cloudy / dingy is from the dirt now blowing into the pool or something else. Appreciate any thoughts and feedback.
    19K Gal, 38'x28' (free form), depth 3 1/2' to 8 1/2', Vinyl, Astral Variable Pump (P280), 25" Sand Filter, Astral VX SWG,
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,680
    Re: Cloudy water all of a sudden
    No CC, I'd keep doing what you are doing and maybe run the pump a few more hours a day due to the chance it could be dirt blown in.
    Solar Blanket, Well Water, Borax Added. 68
    May 2014
    Current: Singapore Previous: Clayton, Victoria, Australia
    584
    Probably dust/dirt unless they're doing a lot of digging. Run OCLT if you're worried.
    FC/CYA ratio is ok for SWG.
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,680
    Sorry, had to delete some of previous answer.
    I saw the 55 CYA and "assumed" it was a bleach pool. Seeing you have a SWG (thanks Abigail ) the CYA is low and you should add some to get up closer to 70 or 80 and then add 1 or 2ppm FC.
