Thread: HELP! Vacuum was taken out of pool with the pump on.
    May 2014
    Atoka, TN
    26
    I was out of town and it was left like this for a few days... The pump still works but as it draws water in to the pump basket it looses the water when returning it to the jet. It builds up then releases it. My filter pressure is around 2 when normally it is 12.
    When I shut it off the pump basket is full of water. When I close off the skimmer line it remains full. But when I start the pump it pulls the water out of the pump while it is being filled again. Repeats this cycle. I backwashed, ran in recirculate mode, and still the same thing.
    25,600 gallons
    33 Ft. 52 Inch AG buried 2 FT. Chlorine
    250 lb Sand Filter 2HP Hayward Pump
    30,422
    Re: HELP! Vacuum was taken out of pool with the pump on.
    Is your pump sucking air through the skimmers?
    May 2014
    Atoka, TN
    26
    I found the problem. Replaced the pump basket housing lid. Added a new hose to boot. Running Great thank goodness. Now Im SLAMing.
    25,600 gallons
