Thread: Hayward Swimpure Plus
    christo's Avatar
    Aug 2014
    bannockburn/md
    9
    i've got a new hayward swimpure plus and pushing the diagnostics button does NOTHING. the display is stuck on water temp.
    is the button broken? is there any setup/reset process?
    Quote Originally Posted by JasonLion View Post
    From the manual
    Diagnostic Displays
    Be sure to have the following information
    Sequential pushes of the small "diagnostic" button next to the LCD display will cause the Swimpure RJ to display the following information:
    1. Pool temperature (degrees Fahrenheitor/Celsius)
    2. Cell voltage (typically 22.0 to 26.0 volts when chlorine is being generated ,other-wise 30-35V)
    3. Cell current (typically 2.50 to 4.00 amps when chlorine is being generated, other-wise 0 amps)
    4. Desired Output % ("0P" -- "100P" depending on knob position )
    5. Instant salinity (-xxxx ppm or -x.xx grams/Liter)
    6. Product name sent to the display ("AL-6" signifies "Swimpure" (STD), ("AL-7 signifies "Swimpure RJ Return-Jet")
    7. Software revision level (r1.xx)
    On the 8th push of the button the display will revert back to the default salt display. Also, if the button is not pushed for 30 seconds, the display will revert back to the standard salt display.
    ~20K gal, IG 1980s sylvan concrete with hot tub and love seat, pentair intelliflo vf pump, 48 sqft hayward de filter, raypak ng heater, hayward swimpure plus SWG, dolphin deluxe 4
    Jun 2010
    Chesterfield,VA
    17
    Re: Hayward Swimpure Plus
    It does sound like the button is broken, it should go through the items like salt level, temp, % etc. I don't really know how you would reset. I'm sure you have turned the unit on and off but other than that you could call Hayward. They might can give you some info. Good luck.
    18X36 Vinyl IGP, SWG,1HP Hayward Superpump, Sand Filter
    christo's Avatar
    Aug 2014
    bannockburn/md
    9
    turns out the little cutout in the decal that covers the whole front was holding the button down. now that it is freed the button cycles through the readings.
