Results 1 to 7 of 7
Thread: Borates???
    elainerader's Avatar
    Apr 2013
    Columbia, MS and Blue Ridge, GA
    120
    Borates???
    Any comments on adding borates??
    25K GALLON IG VINYL
    LASER SAND FILTER, Hayward SP2610X15 Super Pump 1.5 HP Pool Pump
    UNDER WATER LIGHT
    14 YEARS OLD, LINER 5 YRS OLD
    Re: Borates???
    I use with great success. Getting others in town to also move in that direction due to crystal clear water with that HD shimmer! This site has tons of information, just search for borates and read until comfortable.
    Apr 2013
    120
    Re: Borates???
    Thank you!
    25K GALLON IG VINYL
    UNDER WATER LIGHT
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,683
    Re: Borates???
    I did it early this year and the water does seem to feel "softer" and it's stayed cleaner. I think it was worth the time and effort.
    Solar Blanket, Well Water, Borax Added. 76
    northrn's Avatar
    May 2014
    Cincinnati, OH
    532
    Re: Borates???
    Quote Originally Posted by kiss4afrog View Post
    Same.
    27' AG 18K Gallons ~ Cartridge Filter ~ Pentair 1.5 HP Pump
    Jun 2014
    860
    Borates???
    I just did it yesterday. Great results.
    My only suggestion would that you consider using boric acid instead of the borax/muriatic acid method. Boric acid is the more expensive option but it was so easy to do (easy to measure and dissolves fast) that I really think it ought to be the front-up approach that is taught in this forum.
    Borax can substantially raise your pool's pH which is why it is necessary to down adjust the pH first with acid and then make sure you have enough MA on hand to hold down the pH rise. I feel like there's too much room for error there especially for folks that have naturally high CH like in the SW. A massive pH spike can lead to calcium scaling which is no fun to deal with.
    My vote is for boric acid - Duda Diesel is a good supplier and you can order direct from them online or through Amazon.
    One more point - do the borates when your water chemistry is balanced and at the right TFP target levels for your pool. Also make sure you have test strips to measure borate levels with so you can adjust as needed.
