Thread: Pool starting to look a little cloudy
    Oct 2013
    Mount Juliet TN
    8
    I am having a similar issue. Pool has been clear all summer long, but in the last few days starting to look a little cloudy. Just took readings below.
    FC -- 4
    CC -- 0
    PH -- 7.6
    CYA -- 55
    TA -- 90
    I use SWG system and supplement with Liquid Bleach when needed. Tuesday of this week they started construction on 3 lots near my house and now have 3 open lots near my house with dirt piles. I'm not sure if the cloudy / dingy is from the dirt now blowing into the pool or something else. Appreciate any feedback.
    19K Gal, 38'x28' (free form), depth 3 1/2' to 8 1/2', Vinyl, Astral Variable Pump (P280), 25" Sand Filter, Astral VX SWG,
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,672
    Re: Cannot clear up a cloudy pool, have tried everything!
    With your numbers looking like that AND knowing about the construction I would lean towards dirt blowing in.
    Maybe add so DE to your sand to help filter out the fine dirt. I wonder if a sock over skimmer basket will help filter out the tiny stuff as well.
    Do you turn your pump off at night? Does the dirt settle on the bottom?
    Kim
