Thread: CH Too Low??
    Jul 2014
    Puyallup / WA
    2
    CH Too Low??
    Current numbers:
    Date 8/23/14
    FC - Free Chlorine 3.6
    PH 7.5
    TA - Total Alkalinity 70
    CH - Calcium Hardness 100
    CYA - Cyanuric Acid 30
    Based on the recommended level of 220 - 350, my level seems low.
    Is this an issue?
    Thank you!
    In Ground: Viking / Material: Fiberglass / Gallons: 19600 / W x L: 15' 10" x 39' 7" / Shallow - Deep: 3' 5" x 7' 11" / Surface area: 506 / Install: 08-2000
    Pump: Hayward Super Pump II 2.0HP / Single Speed
    Filter: Hayward / Model: S310T / Type: Sand
    SWG: Eco-Matic / Model: ESR 160
    38,521
    Re: CH Too Low??
    For a fiberglass pool, you should not have a problem.
