Results 1 to 10 of 10
Thread: CSI
    Wildcat's Avatar
    Jun 2013
    309
    CSI
    First, the good news. A little over a year ago my numbers were
    FC 12
    CC 0
    PH. 7.6
    TA. 120
    CYA. 160+:
    CH 550-600
    Today
    FC 8
    CC. 0
    PH 7.2
    TA. 60
    CYA. 60
    CH 490
    Obviously I have drained water over the past year. I guess well over half the total refill over time was rain as I am against wasting water in the desert. We have had 4-5 inches of rain in August, as we'll as a few in July. I am so happy it has gone as I hoped.
    Besides CYA down to where I want it with all the sunshine we get here in Tucson, the CH has also dropped.
    With a Pebbletec pool (plaster underneath I imagine) and CH of 490 is my CSI of around .38 preferable or is my TA too low?
    10000 Gal, IG Pebbletec, pop up cleaners,Hayward EcoStar VS, 425 sq ft Hayward Cartridge, waterfall feature
    May 2014
    Current: Singapore Previous: Clayton, Victoria, Australia
    584
    Re: CSI
    I'm not getting a CSI anywhere close to 0.38 with your new numbers unless I use a temp of ~185F. Can you please check?
    I would advise keeping TA as it is. Higher TA would contribute to higher pH and a combination of increased TA and pH pushes your CSI nearer to scaling, more so than temperature alone.
    Wildcat's Avatar
    Jun 2013
    309
    Re: CSI
    Quote Originally Posted by Abigail K View Post
    I still get .37 CSI with my numbers,
    May 2014
    584
    Re: CSI
    Wildcat's Avatar
    Jun 2013
    309
    Re: CSI
    I resized my pool closer to 10000 gal, but either way .3 is very close to .37
    May 2014
    584
    Re: CSI
    Pool size does not change CSI, and PoolMath shows negative 0.3, rather than positive 0.3 or positive 0.37, unless I'm missing something?
    Smykowski's Avatar
    Sep 2011
    3,065
    Re: CSI
    She's right. I can tell just by looking without even going to PoolMath. TA of 60 and pH of 7.2 means your CSI can't be that high.
    Can you post a screenshot of PoolMath after you put the numbers in?
    Wildcat's Avatar
    Jun 2013
    309
    Re: CSI
    I had another bad day, yes it was a negative -.37, not a positive .37.
    I knew what I meant! Sorry for misleading
    May 2014
    584
    Re: CSI
    I stand by my original recommendation of leaving TA as it is. CSI is still within recommended range and taking your location into account, CH would accumulate if you top up your pool with municipal water.
    Wildcat's Avatar
    Jun 2013
    309
    Re: CSI
    Thanks, I appreciate the confirmation. I only measured fill water here once but it was 100. Another reason I prefer to try and go slow and fill with rainwater whenever I can
