Thread: 3 weeks away=no chlorine / Where should I start?
    melbajr's Avatar
    Aug 2013
    Florence, SC
    54
    Question 3 weeks away=no chlorine / Where should I start?
    Latest test results:
    fc=0
    cc=0
    ph=7.5, can I trust this number?
    ta=70
    ch=100
    cya=40
    I'm not sure what numbers to trust or what I need to do 1st.
    Also, i backwash my filter every other week or so (low bather load) but i've never opened it to clean it out. Maybe I should start with that?
    Grecian 11,800 gal. IG vinyl, Pentair TA-60 sand filter, 1.5 hp Superflo, built in 2007, replaced vinyl & converted to Intellichlor IC-40 SWG in 2012 after we purchased home. TF-100 Testkit, SWG manufacturer recommends salt levels 2600-4500, ideal being 3400-3500. Polaris 180 vac.
    melbajr's Avatar
    Aug 2013
    Florence, SC
    54
    Re: 3 weeks away=no chlorine / Where should I start?
    the chlorine/cya chart doesn't cover my low cya. should I raise that?
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,610
    What does your water look like?
    If your pump was running for at least 30 mins. before you tested you can trust all of the numbers.
    If your water looks okay I would add some chlorine. If it is green I would start a SLAM (link below)
    http://www.troublefreepool.com/conte...ntain-shocking
    Kim
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,193
    Quote Originally Posted by melbajr View Post
    To see other FC/CYA combinations not listed on the chart there is a LINK at the bottom with the raw number chart developed by chem geek. With CYA 40 your minimum CYA is 2.9 and your target is 4.6
    Kim asks the key question, how does your water look? If it is clear I would bring it up to at least 10 and do an Overnight FC Loss Test (OCLT) tonight just to make sure nothing is growing. If the OCLT is clear let the FC drift down to your target level.
    If it is cloudy, green or you fail the OCLT start a SLAM.
    How did FC get down to "0" if you have a SWCG?
    Support the site
    melbajr's Avatar
    Aug 2013
    Florence, SC
    54
    How did FC get down to "0" if you have a SWCG?[/QUOTE]
    I don't know, but it is also telling me that my salt is low.
    water has a green tint, gonna start slam now!
    May 2014
    Franklin, NC
    9,193
    Others will answer up (I don't have a SWCG) but I believe it shuts down when the salt goes low.
    Keep us posted on the SLAM and double check those salt levels.
    Support the site
