You could keep the 1000 gph pump, but going to a better pump would give you a bit more head to work with. Also, that would change from a draw-through/suction filter to a pressure filter, which works much better. The added flow/pressure from the better pump coupled with multiple paths in your solar collectors will do a much better job of heating the water.
When I suggested the manifolds, I meant that you could cut the hoses in the collector and add new ends to the shorter pieces of hose. This would be a good off season project for you.
One thing though, if you go with a better, higher flow pump, you'll have to get the proper pool wall fittings to match. I would suggest not cutting out the old hose fittings, but rather adding the new fittings in new holes. That way you can still use the old for other purposes later.
