Results 1 to 8 of 8
Thread: Can't get all the sand
    Jun 2014
    Houston
    3
    I have a Polaris 280 that runs about 10 hours a day, and I can never seem to get all the sand out of the pool. It usually collects in the shallow end, on the sides, and on the steps/tanning ledge, so I push it to the deep end. I empty the bag on the cleaner every couple of days and it will have a decent size clump of dirt but doesn't seem like it is getting nearly all of it. When I watch the cleaner roll by the dirt it doesn't look like it's vacuuming it, just kind of spraying it off the floor of the pool. Any advice how to make the cleaner more effective? There is still fresh sand around the pool since it was only installed last year, but it is at a lower elevation and I can't imagine that much of it is blowing in the pool that the cleaner just can't keep up.
    I'm a new pool owner so bear with me, any help would be greatly appreciated.
    30,432
    Re: Can't get all the sand
    The most common cause is that it is not sand but rather dead algae that is falling to your pool floor.
    Can you post a set of current test results?
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    Welcome to the forums.
    Hope you don't have a cracked lateral.
    Smykowski's Avatar
    Sep 2011
    3,065
    Have you tried touching/picking it up? Are you sure it's sand?
    Jun 2014
    Houston
    3
    26,000 gallon. SWG, plaster. 4800 ppm salt (unsure of this result because it wasn't this high last time and it's rained a lot sense then....) vs manufacturer recommendation of 4000. pH = 7.8 (haven't added acid in a few days). FC = 4. CC = 0. CYA = 80. Alkalinity = 50. CH = 450.
    I'm not sure it's sand. It feels like it and I get clumps of what looks like mud in the vacuum bag. Could very well be dead algae, but I have it even when my levels seem perfect. Could it be some sort of tree pollen? I live next to a forest.
    Attached a couple of pictures, but they aren't too clear. photo 1.jpgphoto 2.jpg
    Thanks for the help.
    30,432
    It's all guesswork without test results but the chances are quite good it is dead algae and you need to SLAM your pool.
    Glock's Avatar
    Jun 2012
    Mesquite, Texas
    866
    I have the same thing in my above ground right now and its dead algae. I agree with duraleigh.
    18x34 Doughboy AGP 22300K Gallons - Build Thread
    Aquaview 24" Sand Filter - 1.5 HP Powerline Pump - Barracuda Ranger - Taylor K-2006 - BBB
    Pool School and Pool Calculator
    wellsnlisa's Avatar
    May 2014
    Cypress, Texas
    47
    Do you have a lot of stone work, or flagstone coping? The type of soft flagstone we get in Texas doesn't seem to be a good mix with salt systems and can cause sand in the pool as the salt slowly wears it away.
    19,000 gal aqua blue pebble sheen, 3.5-7 ft. depth, chiseled flagstone coping, spillover spa, raised back wall with stacked stone face including two columns and curved wall water feature with three 18" sheer descents, two bubblers on 5' x 10' suntanning shelf, Pentair IntelliFlo Variable Speed, Pentair FNS Plus 60 sq ft DE filter, Pentair Mastertemp 400K BTU, Pentair Legend, Rainbow 320 chlorinator (now unused), K-2006 test kit.
