Thread: Should we slam a fresh fill
    Aug 2014
    Litchfield, CT
    7
    We recently installed an inground pool and had water delivered on monday. We have the TF 100 test kit on order and it should be here friday.
    This is a green tint (not strong, but somewhat noticeable) only in the deep end. The shallow end is crystal clear.
    We have put bleach in to raise the FC to 2 and added stabilizer on wednesday night. We can't do the reading of the CYA until we get the new kit, but we are presuming it is at 40, based on how much stabilizer we put in.
    Last night the reading were:
    FC: 2
    PH: 6.8
    TA: 40
    We put in 60 oz of 8.5% bleach and a box of borax (76oz) and about a pound of baking soda (based on what pool calculator told us).
    Here are the current readings today.
    FC: 2
    PH: 7.6
    TA: 40
    These we taken using a pool master 5 way tester.
    The question I have is, should we have "slammed" the fresh fill?
    Also, how long should we run the pump? - we have been running it 24 hours a day. Mostly at speed 3 (2150 RPM's+/-). We are now slowing to down to Speed 1 (750 RPMS+/-).
    Thank you for your help. We have found the website extremely helpful and going the BBB way vs all the pool store chemicals. We have a Hayward inline chlorinator, but we have chosen not to use it as of yet.
    Accounting MaMa
    21,500 gallons, IG, 18x36 vinyl, Pentair CCP420 Cartridge filter, Pentair IntellifloFX VS Pump, Pentair Ultra temp Heat Pump 140,000 BTU,
    Interfab G-Force 2 Slide, Pentair GloBright LED Lights, Installed 8/18/14,TF-100 Test Kit
    38,371
    Re: Should we slam a fresh fill
    Welcome to TFP!!!
    There is usually no need to SLAM a fresh fill.
    Check out Pool School about the pump run time, mostly trial and error: http://www.troublefreepool.com/conte...-pump-run-time
    Oct 2013
    Chapin, SC
    1,141
    Trying to figure out how you got 1 lb of baking soda in pool math? That would only increase TA by 3.4 ppm My pool math shows to go from 40 to 80 would take about 12.3 lbs
    Pool size: 24000gal inground Vinyl-Taylor k-2006 and k-1766 test kits and-speed stir
    Intermatic P1353ME digital timer w/freeze sensor
    CircuPool Si-45 SWCG System
    Polaris 280 vacuum/Polaris PB4-60 boost pump
    Pentair IntelliFlo VS 3hp Pump--Pentair sand filter
